Old 10-24-2009, 10:33 AM   #1
ibad57
ibad57's Avatar
rear-bag air connection?
Doe's any one got pic of conection from top of bag thru frame pic
I need to know what to use to raise quick conect thru frame and is a 90% needed?
The only pic i have shows lower half of frame and hole's seem to be cramped with the with on my frame mabe use allen cap screws to solve clearence be cause wrench maynot work
also need to know specks on lower bolt length for bottom of bag factory hole seams fatter than bag bolt ?
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172
ibad57 is offline   Reply With Quote
Old 10-24-2009, 10:35 AM   #2
ibad57
ibad57's Avatar
Re: rear-bag air connection?
The bolts to secure bag on top seem to be further apart on my RE7 to wide
Old 10-24-2009, 12:11 PM   #3
kev2809
low n' slo
kev2809's Avatar
dont really use the holes as ref. guide in that pic, it just shows what your gonna have to drill. im using 2600 dominators and my holes are way wider than those. im also using 45 degree fittings, and drilled a hole big enough for the whole fitting to go through, that way you can tighten the fitting as tight as much you can before you put the bag in. for the bottom bag bolt its 3/8-16, 4 inches long with a thick washer, make sure it's grade 8. for the top im using 3/8-16, 1.5 inches long, grade 8 with a small washer. hope this helps
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-24-2009, 01:25 PM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
on top I added a 2" long hard line (pipe) straight up then put a T on it ran one side to the valve the other to the guage it worked very well I alos add 3" of hard line to get it out of the crossmember it makes it easy to service if ever needed
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
