Old 10-25-2009, 04:07 PM   #1
57larry
bellhousing question
was the bellhousing for a 71-72 V8 alum. or metal? can't find a search
57larry is offline   Reply With Quote
Old 10-25-2009, 04:45 PM   #2
LONGHAIR
Re: bellhousing question
Uh,....yes?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-25-2009, 04:52 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Uh,....yes?
He's a little vague but I guess what LONGHAIR is referring to is that aluminum is metal...
To the best of my knowlege all of the truck ones were cast iron.
LockDoc
Leon
Old 10-25-2009, 04:58 PM   #4
57larry
yea, I should have said cast or alum. didn't think I had to say the difference, gosh!!
Old 10-27-2009, 09:07 PM   #5
Myself
So, is it hard to find an aluminum one then?? Or just not on 67-72 models? My buddy and I bought an '82 truck for parts. He kept the SM465 cause he uses them in his pulling trucks. I kept the 12 bolt rear, and the front crossmember. This truck had a 305 and an aluminum bellhousing. I kept it thinking I might actually use it someday.
Myself is offline   Reply With Quote
Old 10-27-2009, 09:52 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The aluminum ones are quite common. Like you found, later trucks used them. The difference though, is that the early cast iron units had provisions for mounts to the crossmember on the bottom of them that the later ones lack.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-27-2009, 11:10 PM   #7
sweet70beast
sweet70beast's Avatar
The Center hole on the newer truck aluminum bells is bigger than the older cast iron ones. The older truck iron bellhousings and the car aluminum bells had the smaller holes because the bearing retainer on those trans were smaller.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
