10-27-2009, 08:33 PM | #1 |
Transfer case comes loose 05 2500HD
My co worker has a 05 2500hd 6.0 with the 4l80e trans. He keeps having trouble with the transfer case coming loose. It will break the studs off. It has done it 3 times now. transfer case problem?? Any suggestions???
10-29-2009, 10:27 AM | #2 |
Re: Transfer case comes loose 05 2500HD
The case is aluminum so when it gets hot then cold it expands and shrinks letting the hardware back out. Tell him to put some red thread lock on the hardware when he puts it back together. It will keep the hardware from coming out.
1972 Chevy C-10 Lowboy 1972 Chevy K5 Blazer Hi-boy 1948 Plymouth Club Coupe |
11-03-2009, 01:23 PM | #3 | |
Charlie Daniels w/ a Tq Wrench
DO NOT use loctite on the hardware, and BE SURE that only the correct coated bolts from GM have been used, otherwise it will create a galvanic reaction with the magnesium in the transfercase. This could also be part of his problem with the transfercase coming loose. I have never heard of this being a problem though. Any bad u-joints causing vibrations and possibly loosening it up? Last edited by GCncsuHD; 11-03-2009 at 01:31 PM. |
