Old 10-28-2009, 08:54 PM   #1
abilityonline
68 c 50 carb flooded
I could use some expert advise for my 68 c50. I had it idleing for about 40 minutes while I was loading it with a load of manure. On my way home I was stopped idling at an intersection and it died on me. Wouldn't restart. I had to let it sit for about an hour loaded with 14 yards of horse crap. LOL ( In the way of people trying to leave a sub division). Once I got it started I drove it home but when it was idling again it died and wouldn't start for about 30 minutes. The carb was cleaned this summer. Is there an adjustment I could make?
Also, I believe the carb is factory.
abilityonline is offline   Reply With Quote
Old 10-28-2009, 09:11 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 68 c 50 carb flooded
Several things come to mind.First there is a strainer in a pick up fuel tank that can become clogged,usually this will allow it to idle but have no power etc.There could be something similar going on with it.
Second is vapor lock,Are the fuel lines run near the exhaust or any other heat source.
Third is it possible the fuel pump is weak supplying enough fuel when rpms are up but dropping supply off when idleing.
The carb probably has a "sintered metal"(looks like lava made of brass.They can become clogged.
These are just a few things it could be that come to mind.I'm sure others will chime in with suggestions also.But be warned, they're gonna want pics since they are a bunch of pic Ho's LOL.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-28-2009, 09:18 PM   #3
abilityonline
Thanks!
I've been looking around and I think vapor lock or the carb and fuel heating up is the first place I'll look. I'm not sure how to insulate the carb or fuel lines from engine heat.
Old 10-28-2009, 09:23 PM   #4
abilityonline
I'll see if I can track down an aluminum heat shield for my carb
