Old 10-28-2009, 09:43 PM   #1
imaguywithemail
imaguywithemail's Avatar
1970 trouble...
So I'm almost done with my chassis swap, but am having some trouble. A few weeks back I took her for a drive, and about 2 blocks from my house the rear-end locked up on me. I thought I'd gone into two gears at once, so I ordered a new installation kit from hurst, installed it, but am still having trouble. I'm about 99.9% sure it's not the transmission, because I can shift into each gear, including neutral and reverse, without trouble. In fact, when I release the clutch the truck will move about 1-2 ft forwards or backwards then stop and i have to clutch or stall. My question now, is that I heard that it's possible it's my emergency brake that's causing this. I got kind of hasty while doing the swap and disconnected the cable running to the parking brake pedal in order to save time during the actual swap. So my parking brake cable is just sort of hangin out under the truck, with no tension. My question is, is it possible that the emergency brake has retracted and the rear brakes are now locked? Just trying to figure out what could be going on with the least amount of tearing apart. Thanks a bunch.
imaguywithemail is offline   Reply With Quote
Old 10-28-2009, 11:14 PM   #2
1968CHEVYC10
1968CHEVYC10's Avatar
Re: 1970 trouble...
big chance I could be wrong, but I think it wouldn't be because of the e-brake, because when a working e-brake is engaged it tightens the line, and its loose when its disengaged, so I'm not sure how a disconnected line could cause it to lock up. when I got my truck all the brakes had locked up I think from just sitting with the e-brake on to long, and I don't the think wheel cylinders where any good. thats my 2 cents.
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 10-29-2009, 04:25 AM   #3
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: 1970 trouble...
Did you consider that it might be a problem with the differential? I'm not saying that it is but there doesn't seem to be a lot of other options.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 10-29-2009, 07:00 AM   #4
cdowns
cdowns's Avatar
Re: 1970 trouble...
i'd put it on jackstands disconnect drive shaft take brake drums and diff cover off and start lookin at things
Old 10-29-2009, 09:35 AM   #5
jay6891
Car Knocker
jay6891's Avatar
Re: 1970 trouble...
If it was me, I would pull the cover off the diff and see if the the pin in the carriers has some how come loose and hanging about half way out. Hitting something inside on the half turn and locking up.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 12-16-2009, 11:56 PM   #6
imaguywithemail
Re: 1970 trouble...
yup it was the differential. I ended up breaking up with my girlfriend who's house I was keeping it at, so I had it towed to a shop the next day. The diff had no oil in it when I thought it did, and in a fatal moment of stupidity and eagerness I didn't check DOH! So the rear diff locked up, I got a new one put in for me and now she's driving again. Almost. I still gotta move the engine two inches back, reconnect the rear brake lines and put an exhaust on. Then she'll be up and terrorizing the streets of Eureka once again!
