Old 10-30-2009, 01:36 PM   #1
bamafrost
bamafrost's Avatar
Need help with bucket seat riser dimension
Can anybody in the forum help me with some stock buddy bucket seat dimensions?
I could sure use the following dimensions off a stock buddy bucket seat:
A). the height from floorboard to the highest point on the front
of the bucket seat
B). height from floorboard to the highest point on the back of the seat bottom
C). height from floorboard to the very top of the bucket seat
If somebody can help me with these dimensions I'll be very appreciative.
Thanks in advance.
Tom
Bamafrost
"Wars fought, uprisings quelled,
Coup d'Etats planned...right after my nap".
'68 Rambler American 2 door post
Built 340/727/8.75 w 3.73 posi
'68 C10 shortie soon to have a 2.5/4 drop
and new Americans: 16" x 8" chrome IROC's
bamafrost is offline   Reply With Quote
Old 10-30-2009, 08:38 PM   #2
AustinScott
AustinScott's Avatar
Re: Need help with bucket seat riser dimension
do you need the driver, pass, or the "buddy" seat info?
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline   Reply With Quote
Old 10-31-2009, 07:19 AM   #3
bamafrost
bamafrost's Avatar
I could use both the driver's and passenger seat dimensions...I will just "float" the aftermarket repro console between the two. Putting BMW in my '68 and want to get the placement as close to orig. as possible. I appreciate your help!
Thanks. Tom
Bamafrost
Old 10-31-2009, 08:47 AM   #4
JimKshortstep4x4
Here are the dimensions that I came up with. The passenger and drivers seats are the same. There is a curvature to the seat cushions so I measured at the highest point which is in the middle of the cushions.
A dimension 12"
B dimension 10 1/2"
C dimension 30 1/2"
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-31-2009, 09:11 AM   #5
AustinScott
As stated above... just a picture to go along.
If i had a choice, I'm 6' tall and would drop the seat by 1-2" this would place my center of vision closer to the center of the windshield. As it sits now my center of vision is in the upper 1/3 of the windshield.
Old 10-31-2009, 02:28 PM   #6
long69
those dims look the same as i measured for my bench. i will be installing some 97 325 bmw (e36)power seat in mine and have determined that i need to raise the seat track 2". the seat back will stick above the bottom of the rear window same with the head rest. IF i'm lucky i wont loose any leg room and gain maybe an inch. i wil use 2x4 square tubing for the spacer as well as re-enforcing the floor. gonna put em in during x-mas shut down.
long69 is offline   Reply With Quote
Old 10-31-2009, 03:16 PM   #7
bamafrost
bamafrost's Avatar
Thanks...that's about what I came up with also. I am only 5'-9", so I don't need to raise it much to get centered in the windshield are...plus, with all the tilt options with the BMW seat I should be able to get a good angle for my back.
Tom
Bamafrost
