Old 10-30-2009, 07:16 PM   #51
PBFAB.COM
PBFAB.COM's Avatar
Re: More New Products from Porterbuilt Street Rods
Originally Posted by ratty 46 View Post
I've also got a question ....... lower tube A-arms for a 3500 GM .... do you build them? Say a mid to late 80's square??
Thanks.
Ratty 46
We sure do! Bottom pic, the one with the larger BJ cup.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-30-2009, 10:57 PM   #52
04 orange
04 orange's Avatar
Any up dates on hood hinges for 67-72 trucks??
04 orange is offline   Reply With Quote
Old 10-30-2009, 11:36 PM   #53
ratty 46
Kewl ........ any with conventional spring pockets? or just the air?
Ratty 46
ratty 46 is offline   Reply With Quote
Old 11-21-2009, 07:56 PM   #54
dan468
dan468's Avatar
Originally Posted by porterbuilt View Post
To order the new Dropmember V3.2 go here- LINK
The Dropmember V3.2 is the latest addition to the Dropmember family! It’s round tube structure, strengthened and accented with CNC cut plate make it both structurally rigid and aesthetically pleasing. Other advantages of the new design include: a significant weight savings of just over 10lbs. from it’s predecessor ; and a sleeker, more custom appearance. The Dropmember V3.2 is constructed of 1.5” DOM tubing and .188 pickeled plate. Available for the C10 chassis years 1960-1987.
Dropmember V3.2-
Dropmember V3.2 Stage I kit-$1099 (and free shipping anywhere in the continental U.S.)
Stage I kit includes main crossmember, inner frame support plates, upper control arm/bag mounts, motor mounts (SBC, BBC, LS1, I6), upper shock mount relocators, tubular transmission crossmember, frame notches for rack and pinion clearance, billet rack mount bushings, billet tie-rod ends with hardware, all necessary hardware for kit installation, and instructions via e-mail.
Dropmember V3.2 Stage II: $2100-
Includes Stage I components, plus upper and lower tubular control arms (add $100 for 4130 Chromoly upgrade), ball joints, delrin bushings, billet upper cross-shafts.
Dropmember V3.2 Stage II kit-
Dropmember Control Arms-$1099
(offered in DOM tubing or upgrade to 4130 chromoly for an additional $100)
Complete set FREE shipping anywhere in the continental U.S. (Includes upper and lower control arms, machined Delrin bushings, billet upper cross-shafts, and ball joints)
Porterbuilt Street Rods is now offering it’s own line of C10 control arms to be used with the Dropmember, or factory C10 crossmember. The arms have been designed to work with either factory 73-87 control arm bushings, or machined Delrin bushings offered through Porterbuilt. Factory replacement ball joints from 63-87 press into the lower arms, and bolt-in to the uppers. Ball joint angles have been corrected, and additional caster added
"and additional caster added"
What's this mean considering the caster is adjusted in the shims? Sorry, still learning.
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 11-21-2009, 10:05 PM   #55
PBFAB.COM
PBFAB.COM's Avatar
Shims will adjust the castor, but won't change the amount of castor built into the arms design.
For example, lets say we start with 2 degrees of castor, and by adding shims we can get up to 2 more degrees... that equals 4. But if we start with 4 degrees of castor, we can end up getting 6 with the shims. Hope this explaination helps!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-22-2009, 12:17 AM   #56
Rokcrln
Rokcrln's Avatar
Yep I am thinking a set of upper C4 arms with adjusted BJ angle's would fit right in here with the rest
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-22-2009, 11:32 PM   #57
ShowSS12
ShowSS12's Avatar
So dose this mean the older drop members will be cheaper in price?
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline   Reply With Quote
Old 11-22-2009, 11:40 PM   #58
n2billet
Village Idiot....
n2billet's Avatar
He doesn't make the old version anymore.......
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 11-23-2009, 12:28 AM   #59
PBFAB.COM
PBFAB.COM's Avatar
That's right... the new tube version replaced the old one. Stronger, lighter, and better looking! Why go backwards?
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-23-2009, 01:24 AM   #60
ShowSS12
ShowSS12's Avatar
Why go backwards?
B/c I like the older ones better and I was hoping they would be cheaper...
Adam M
STX Designs
Old 11-23-2009, 01:37 AM   #61
PBFAB.COM
PBFAB.COM's Avatar
I know there have been several guys who own the earlier version that would like to upgrade to the new one. Keep your eyes peeled, as a good deal might pop up.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-27-2009, 11:10 AM   #62
gringoloco
A guy with a truck
gringoloco's Avatar
Ratty 46
Also curious...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
