10-30-2009, 10:54 PM | #1 |
Notch is off.
I'm converting a '68 leaf truck that was already notched with a flip kit to a bagged trailing arm set up. In the mock up I'm noticing that the axle needs to move back about an inch or a little more to really sit in the notch. Why would this be. The leaf axle sat right in the notch. I'm going to stick the bed on tomorrow and see what it looks like. I may have to add a spacer between the trailing arm brackets and the crossmember.
BRENT -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
10-31-2009, 12:08 PM | #2 |
Re: Notch is off.
Pics. Any suggestions????
Leaf - Trailing arms w/bags
10-31-2009, 01:25 PM | #3 |
Re: Notch is off.
Got the bed on. I was hoping the wheel would be about an inch or two off so I would know what to do, but it's not. Looks pretty centered to me. Now I don't know what to do. I'm so frustrated.
10-31-2009, 01:29 PM | #4 |
67-72 parts collector,…
Re: Notch is off.
Do you have your trailing arm crossmember "located" correctly?
Your wheels base should be 115 inch. Edit: (I'm a slow typer) Looks centered in the rear fender to me. I would still check the wheelbase length.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-31-2009 at 01:33 PM. |
10-31-2009, 01:32 PM | #5 |
Re: Notch is off.
I would cut out the "weld in" c-notch and purchase a bolt in c-notch. The frame hole will be slightly bigger,... but the extra metal from the bolt in notch will help support it. You could even add some welds to the bolt in notch if you are worried about it.
10-31-2009, 01:46 PM | #6 |
Re: Notch is off.
I did measure where the middle crossmember was and compare it to the one on my coil frame. It measured out right. I just drilled out the rivets on the trailing arm brackets and bolted them to the crossmember on the leaf frame.
10-31-2009, 02:52 PM | #7 |
low n' slo
Re: Notch is off.
that is odd,. guess that means you need a step notch!
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
10-31-2009, 03:03 PM | #8 |
Re: Notch is off.
Very tempting.
10-31-2009, 03:43 PM | #9 |
Re: Notch is off.
Did you check this yet?
That's where I would start.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
10-31-2009, 04:01 PM | #10 |
Re: Notch is off.
Well, the front end is off of it right now. It's down to the bare frame in front. Is there a way to check it without the front crossmember?
10-31-2009, 04:03 PM | #11 |
Re: Notch is off.
If that picture of the wheel in the fender is a straight on shot, then the wheel is back a good inch or two too far.
Follow the fender curve around and note where the tire finally cuts in and out of it. It cuts in way earlier in the back than the front. The wheel is definitely too far back in that picture.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
10-31-2009, 04:30 PM | #12 | |
Re: Notch is off.
10-31-2009, 04:36 PM | #13 |
Re: Notch is off.
But the pictures show the axle is forward of the notch, like the wheelbase would be shorter not longer. It's a head scratcher.
