Old 10-31-2009, 08:01 PM   #1
kcfirstbuild
Where to find parts for power assisted steering?
I just bought a 1968 c10 Lwb with power assisted steering. I had to degrease the under chassis and found a hose had a small cut in it not sure if its enough to cause it to leak. If i need parts where can i go to get parts for that kind of power steering ? Also if i wanted to convert to power steering, which i might want to do. What all do i need ?
kcfirstbuild is offline   Reply With Quote
Old 10-31-2009, 08:43 PM   #2
Jurassic-1
Jurassic-1's Avatar
Re: Where to find parts for power assisted steering?
You should be able to use the existing pump and change the steering box.
Jurassic-1 is offline   Reply With Quote
Old 11-01-2009, 05:57 PM   #3
ges55
BLACK SATIN
ges55's Avatar
You can get the control valves on Ebay under 63-82 Corvette power steering control valve. They are interchangable. Some local part stores have them, but check the price.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
Old 11-01-2009, 09:11 PM   #4
kcfirstbuild
Just so happens i work at a local parts store! Is the control valve known for leaks ? And if i change out the steering box what year power steering box do i look for?
Old 11-02-2009, 09:26 AM   #5
ges55
BLACK SATIN
ges55's Avatar
There is a guy on Ebay that is selling instructions on how to use later model power steering systems on the older trucks. I think it is $15.00 for the plans & knowledge needed.
Old 11-02-2009, 09:35 AM   #6
ges55
BLACK SATIN
ges55's Avatar
It is item #170400503882. He is the bondobandito.
