I have a 1974 long bed chevy c10 2wd. coil springs up front and leafs in the back. i am looking to lift the truck 2in and use 33/12.50R15's. i have been looking into lift spindles for the front and lift blocks in the back. is this a good route as far as parts and tires wear is considered and if so what places should i start looking for the spindles? please help!
Here she is hope it works ![]() Last edited by Back in Black 66; 11-01-2009 at 02:58 AM. Reason: correction |
Re: Lifting a 2wd
any other ideas. i dont really wanna do taller coils. cause i dont wanna deal with control arm length and never being able to align the truck and bad tire wear or would i not have troubles because of it only being 2in?
6.0 powered square
Re: Lifting a 2wd
you can get a ball joint spacers and a 3" body lift
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 11-01-2009 at 11:50 AM. |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Lifting a 2wd
i would do the body lift
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: Lifting a 2wd
balljoint spacer and a 1" taller coil will allow you to run 33's.
Re: Lifting a 2wd
mike d
how reliable is a ball joint spacer and will it affect the alignment? and flamingbig 10 how difficult is a body lift compared to a suspension lift? |
Re: Lifting a 2wd
I don't have any alignment problems. Ill snap a picture this weekend. I know there is a moog spring that works great, I'll look for that part number as well
Re: Lifting a 2wd
I ran 1 ton coils on my 82 c10 and was able to fit 32"s with only slight rubbing. I did not need any lift on the rear as the truck sat level with the 1 ton springs. You could do the 1ton front coils and then a small (1") body lift. I do not like body lifts but a small one isn't too bad. I know my 32x11.50s almost hit the lower edges of the front fenders.. I had less than 2 fingers width at the closest point. The tires rubbed the inner fenders at the top.
Spindles are the best option but as previously mentioned not currently available for our trucks. I have heard and seen a couple people running the 88-98 front lift spindles but have not seen a write up on what particular parts are needed.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Re: Lifting a 2wd
When I bought my truck it had 3" lift coils with the ball joint spacer in it. Then it had the blocks in the back. It had 31x10.50's on it with plenty of room. I can't tell you how it was on tires, or alignment because I changed back to stock pretty soon after I got it.
Re: Lifting a 2wd
When I bought my truck it had 3" lift coils with the ball joint spacer in it. Then it had the blocks in the back. It had 31x10.50's on it with plenty of room. I can't tell you how it was on tires, or alignment because I changed back to stock pretty soon after I got it. Here is a pic of it.
Re: Lifting a 2wd
prerunner 1982 - With the 1 ton coils did you need longer control arms or were you able to use the stock ones?
And does anyone have a pic of a ball joint spacer? i want to know how it works. Thanks guys for all the assistance. |
Re: Lifting a 2wd
No I did not need longer control arms, I believe the same coils were available in diesel equipped trucks whether they were 1 ton or not. Since they were a stock option, no mods were needed.
Ball joint spacers: Though the pics below are for a Toyota the concept/design is still the same. It spaces the ball joint away from the upper control arm and helps reduce the angle the ball joint operates at. Also some of the aftermarket tubular control arms have the ball joint mounting area angled to help reduce the angle of the ball joint. ![]() ![]()
Jonny
Re: Lifting a 2wd
I am currently running 3" coils and ball joint spacers in mine. The spacers are no where near as thick as the ones shown above, only about 1/2" you also chage the mounting from above the control arm to below it. this set-up is designed to eliminate the exact problem you mentioned.
Edit: to clear up any possible misconceptions ball joint spacers do not provide any lift, they simply allow you to get a proper alignment with a huge shim stack and provide room for more droop as the lift coils change the position of the a-arms. I also plan to install a 1 1/2" thick droop stop istead of the stock 2 1/4" one to provide suspension travel closer to stock.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR Last edited by sailed2japan; 11-19-2009 at 07:14 PM. |
#15 |
Jonny
Re: Lifting a 2wd
If you really want spindles:
Originally Posted by suicide 63 The recipe is 73-87 upper control arms any <c10-c20-c30> lower control arms c20-c30 88-98 spindles for 1-1/4 inch rotors any exended cab will have them rotors or a light dudy 3/4 ton they were six lug upper and lower ball joints outer tie rod ends brake hoses calipers What makes this work is the 88 up ball joint presses into the 73 up 3/4 ton lower a-arm Yuo will have to cut about a 1/4 inch off the new tie rod ends to get proper alignment. Dont forget abought 88-91 square body stuff it all interchanges. good luck classic performance products has six lug rotors that go on 73-87 1 1/4 inch spindles about $120 for a pair. Use this with a pair of lift spindles from Fabtech and 4" rear springs
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
#16 |
Re: Lifting a 2wd
holy cow had no idea it would b such a hassle. i never really like body lifts but it is looking like i might go that path. just seems easier. thanks for all the suggestions and ideas. hopefully soon i will get it lifted and i will post pics of what i came up with.
#17 |
Re: Lifting a 2wd
ever see those "donk cars"? I always wondered how they lifted gramma's 4 door grocery getter to clear 30"rims. I saw a kit for $495 in one of the DONK magazines for a 3" kit for a c10. the kit had front spacer cups, ball joint spacers, rear blocks, hardware, and shock absorbers. or you could try some big block or 1-ton coils up front and blocks in the back.
#18 | |
Re: Lifting a 2wd
However, what are you doing looking in a "Donk" mag long enough to find an ad for a c10 lift kit? ![]()
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 11-24-2009 at 10:49 AM. |
#19 |
Re: Lifting a 2wd
it was one of those things where you see the magazine cover at 7-11 and go "WTF?!" and pick it up. good marketing... sparked my interest for sure.
#21 |
Re: Lifting a 2wd
girls? they have girls in those mags? I musta' looked right passed them (my ole' lady's in the room)
#23 |
Re: Lifting a 2wd
Think i am gonna do 1 ton coils and leafs. just seems easy.
#24 |
3/4 Ton Rodder
Re: Lifting a 2wd
On a C20, how much lift would I get with 1 ton coils up front? Or are the springs the same on a C20 and C30?
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. Last edited by Scootin 81 C20; 11-26-2009 at 06:07 PM. |
#25 |
6.0 powered square
Re: Lifting a 2wd
about a 1 1/2
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
