Old 11-03-2009, 02:57 PM   #1
straight axle
straight axle's Avatar
steering column loose
The column on my 84 K10 is loose where the the joint is for the tilt wheel, do I have to replace the hole column or can I get in there and replace the bad part?
straight axle is offline   Reply With Quote
Old 11-03-2009, 04:45 PM   #2
Zoerb
Zoerb's Avatar
Re: steering column loose
this site has some great info
2017 Tahoe Premier - Daily
'99 Silverado 2500
Wife's whip- 2020 Equinox Premier
Zoerb is offline   Reply With Quote
Old 11-03-2009, 05:27 PM   #3
straight axle
Cool thanks
Old 11-03-2009, 10:57 PM   #4
Zane M
Yep, its a tedious job, but it is definitely fixable.
I disagree with the guy who did the write up--which is top notch by the way. I just did this over the weekend and I went ahead and tore down far enough to get all FOUR of the bolts squared away, not just the two that are "easy" to get to.
I figured I had already invested that much time and effort, there was no reason to not fix it correctly and completely.
Zane M is offline   Reply With Quote
Old 11-04-2009, 02:32 AM   #5
Zoerb
Zoerb's Avatar
A couple more FYI's
don't let any of the screws fall into the column, or you'll wind up having to tear it down further
as previously said try to get all four. The last one I did I only got the two tightened down and I'm not sure but I think it still feels loose
on loctight - there is red and blue. One is for locking the treads forever, the other locks it till force is applied. A tech I worked with years ago said that if you want to make enemies, lock it for good. I use the blue stuff and it seems to work good
also I fought with the high beam switch for about an hour till I figured it out.
Best piece of advice - take your time and look at everything as it comes out.
Lastly, good luck!
'99 Silverado 2500
Old 11-04-2009, 09:04 AM   #6
straight axle
maybe I should just replace the column, will an ididit or something similar fit???
Old 11-05-2009, 01:53 AM   #7
Zoerb
Zoerb's Avatar
Depends on the purpose of the truck
500 or more is a lot to drop in for a daily driver
the stock column will take time and will basicly cost nothing in the end to fix
if you still don't feel comfortable with doing it, you may just need to find a replacement column and put it in. Finding one on cl or in a junk yard will be way cheaper than ididit or flaming river.
'99 Silverado 2500
Old 11-05-2009, 07:48 AM   #8
straight axle
Cool I'll keep an eye out on CL, now if I can just find one that is for a 4spd.
