Manual steering
I have a 67 short box with power steering,at the top end it seemed to float so on the second pass I took off the belt and it works alot better.Is a manual steering box still available for these trucks or will something else work like an s10 or newer unit,thanks for the help,
![]() Join Date: Jul 2007
Re: Manual steering
I have a manual box off of a '67 or 68 in mint shape...
![]() Join Date: Jul 2008
Re: Manual steering
I think some 70's will work also,does it bolt 3 bolts trough the inside the frame?
Built chevy tuff! ![]() |
Re: Manual steering
I will check the bolts today I think there is 3 just not positive,
Alex,what would you want for the box,I am near London |
At the body shop.
Re: Manual steering
the pitman arms are differnt between manual and power boxes also. FYI
Active Member
Re: Manual steering
FYI - it is very common to just plug off the lines on a PS box and run it as a manual - it will work just fine and slows down your reaction which is a good thing in a truck going fast down the drag strip.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
Re: Manual steering
There was a power box on my truck when i bought it with the SBC. I thought I'd retain it going to the Gen 3 motor. When my plans changed and decided to go faster than high 13's, I decided to swap it out for a manual box. It honestly drove a million times better. With the power box, it would never return to straight, way tooo twitchy up top.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#8 | |
Sunburst C10!!!
Re: Manual steering
so there shouldnt be any problems
Gage 1967 C10 Shortbed Stepside |
Re: Manual steering
find a manual box and bolt it on and you will be better off!
Sunburst C10!!!
Re: Manual steering
will it turn as easy
At the body shop.
Re: Manual steering
" That didnt make it any newer " " Dont antique the equipment " |
Sunburst C10!!!
Re: Manual steering
well ill just keep my plugged power box
Re: Manual steering
Manual box is also lighter.. Not to mention getting rid of the power steering unit will also shave even more weight..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 11-07-2009 at 02:22 PM. |
Re: Manual steering
#15 |
Sunburst C10!!!
Re: Manual steering
i got the pump off and just plugged the holes with some old fittings that i welded shut
