Old 11-05-2009, 12:41 PM   #1
cjohns
cjohns's Avatar
buffing old paint
Any body have any luck buffing old paint?I've hand polished(buffing comp)but it still needs more or should I say it needs to be done correct.Any help would be great!Clark.
cjohns is offline   Reply With Quote
Old 11-05-2009, 12:59 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: buffing old paint
Sorry, no help on the paint, but that's a sweet truck.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-05-2009, 01:08 PM   #3
UltraBlue71
UltraBlue71's Avatar
Depends on what kind of paint it is I imagine, if its original and just faded I would try a buffing wheel with some fine cut compound like Megiures to try to bring it back, then wax the crap out of it. the main thing with a buffing wheel (wool pad) is keep it moving, not letting the heat build up, especically on a corner, or you'll burn through. Also use one with a speed control on it, start out slow then slowly speed things up when you are comfortable. Hope this helps...
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 11-05-2009, 01:26 PM   #4
cdowns
cdowns's Avatar
looks pretty good to me// using a buffer on old stuff is real chancy in a matter of seconds you can burn thru that old finish . i've seen it done countless times BEWARE
Old 11-05-2009, 03:39 PM   #5
sameyrasmea72
sameyrasmea72's Avatar
Most of the colors on these trucks will buff out nice. But a few of the colors with metalic like the bronze or your color green, If they get too faded no amount of buffing will bring back the shine. Yours looks pretty good though.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 11-05-2009, 05:33 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
The truck that is pictured has the green paint, that once it starts to age it will slowly turn black as the base coat shines throught. My 72 had that color and I finally just repainted the truck to end it's pain. It would be nice, if the older paint jobs were the base coat/clear coat paints of today. but they weren't--so they ploishing of that paint is hard to do without going too far. Topolish paint a mild rubbing compound and a large wheeled, slow speed buffer works best. Once polished, then reseal the paint with a good polish or sealant.
Frank
Old 11-05-2009, 06:19 PM   #7
lofly'a
lofly'a's Avatar
i'd suggest the 3m finesse-it 3 system with a foam pad. the foam pad is a lot more forgiving to burn thru and is a lot easier on the crowns and edges. if you are not familiar with machine buffing techniques. do a search for videos on how-tos
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 11-05-2009, 06:54 PM   #8
cjohns
cjohns's Avatar
Not worried about going through the paint there are dents and scratches all over,this was a farm truck...I just want it to shine!Funny thing is that the box,hood and fenders are painted over black and the cab and doors are painted over red primer???Any reason for this?And it is the original paint.
Old 11-05-2009, 08:09 PM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
I have a porter cable double action polisher that takes foam pads of different aggresiveness . I would start with a white lake county pad and a #6 cleaner/wax . Easing up in aggression only if needed . Orbitals are alot more forgiving and work good if a soft cut is needed .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 11-05-2009, 08:21 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Use a clay bar. They work fantastic.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-05-2009, 10:01 PM   #11
"It`ll buff out."...No i really mean it!
The paint on these trucks was awesome.It`s unbelievable how well it can be revived.But,do be gentle.There`s been some great advise offered already.
Old 11-05-2009, 10:27 PM   #12
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
All of the above advice is excellent but I might add it depends on how deep the dead (oxidized) paint extends into the thickness of the paint. If the paint is really dead, you'll break through to the primer before you reach any shine. If this is the case only repainting your truck will solve it. As to the doors and cab having different color primer, it sounds like maybe they had some body work done on them at some time.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 11-05-2009, 10:42 PM   #13
BossHogg69
motor exploder
BossHogg69's Avatar
Meguiar's 'Swirl mark remover 2.0', Mother's cleaner/wax, then Mother's carnuba wax - I applied the Meguiar's 2.0 with a craftsman buffer (not orbital/DA sander) then the cleaner/wax with the buffer and hand applied the polish/final wax. Worked great on the single stage paint on my '69. I should've taken a pic of the whole truck before I started, but I took one of the inside of the bed, inside the yellow circle is what the whole truck looked like. the second pic is right after I backed it out of the garage after buffing/waxing.
Before this, the truck had sat outside for about 10years uncovered...
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-05-2009, 11:38 PM   #14
1956cameo
1956cameo's Avatar
As mentioned before, my 72 suburban had dull paint like the blue one pictured above. Used Meguiars swirl and scratch remover and buffed it by hand, it ended up looking like a new paint job again.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 11-06-2009, 12:07 AM   #15
big_al_71
big_al_71's Avatar
+1 on the meguiars products...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-06-2009, 11:06 PM   #16
factorystock
factorystock's Avatar
Yes, that is the way it was done at the factory, but don't know the reason why.Your factory paint looks very presentable the way it is, how many base coat clear coat jobs will last 40 years?
factorystock is offline   Reply With Quote
Old 11-07-2009, 05:23 PM   #17
piecesparts
If it is done right, the paint will last a long time, no matter what the type.
Frank
