Old 11-06-2009, 09:43 AM   #1
Hair
Shifter linkage clamp bushing?
71 GMC Powerglide
This is the clamp that holds my shifter linkage to the steering column.
The hole in my steering column is .6" diameter and the bushing that is on the clamp is only .5" diameter so there is a lot of play/slop. It also seems like the nut and lockwasher could "almost" pull through the .6" hole. When I removed it, the bushing had a bunch of, what looked like, teflon tape wrapped around it. Looked like maybe some one had tried to rig it up.
Am I missing something here? Is it supposed to be that sloppy? Is that bushing supposed to have a rubber bushing around the outside of it or something?
My shifter had a ridiculous amount of slop in it, and I found most of it in the worn out shifter linkage at the transmission (fixed that), but I'm thinking that something may be missing here as well.
A picture of a correct one or and info would be appreciated thanks.
Hair is offline   Reply With Quote
Old 11-06-2009, 11:52 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Shifter linkage clamp bushing?
If I'm not mistaken they should all be the same. I read a post where someone ordered parts from Ecklers and they had the correct one. In the meantime, I'd go to a junkyard and see if you can acquire one from a 350 tbh (if you can't find a powerglide) to compare to.
http://www.classicchevy.com/product....dept%5Fid=1849
http://www.classicchevy.com/product....2&dept_id=1849
68gmsee is offline   Reply With Quote
Old 11-06-2009, 12:06 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
This is the best I can do. The lower rod to the trans linkage goes through the hole in the adapter and the bushing goes through the hole in the arm that comes off the steering column.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-06-2009, 12:40 PM   #4
68gmsee
Active Member
68gmsee's Avatar
forgot to add:
Some years ago, I made some bushings out of metal tubing and clear plastic hose for the lower and upper shift arms. Also when the rubber around the metal insert piece fell to pieces on my GMC I used a piece of clear plastic hose.
