Old 11-04-2009, 01:09 AM   #51
Puropedo
Re: LFD's project white lightning -- 1968 fleetside "basically stock"
Isnt that like a solar powered system? I hear they are pretty expensive but in a few years it will pay for itself.
Puropedo is offline   Reply With Quote
Old 11-04-2009, 02:59 AM   #52
67ChevyRedneck
67ChevyRedneck's Avatar
With your rep, I'm sure you'll be welding lots more rockers on with that thing (plus whatever you're using it for anyway.) You'll have that $ back in no time
Cab is looking great and those spot welds look really cool on there.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-04-2009, 03:06 AM   #53
Rokcrln
Rokcrln's Avatar
Yes you are correct the system I am looking at is about $15-20k with a few $k back from the state it is supposed to be a 5-6 year return on your investment.
Thank you, and yes it will get used for years to come.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-06-2009, 09:17 PM   #54
Rokcrln
Rokcrln's Avatar
Starting the wire gutter molding as well as the passenger side copy of the drivers side. On the copy plate I went ahead and rolled an edge into the piece to match what was their as well as giving it a lot more rigidity before welding the gutter cap in place. As you have seen before I am doing an LFD signature wire gutter cap at a 45* angle. I just like it this way the best for a smooth and simple look but being anything but simple to do right.
Before doing any welding I first treated the bare metal gutter, then seam sealed the factory seam before coating it with a good top coat.
I also added a pic of my gas pedal adapter plate installed for using a cable style in the older linkage style cab. This will bolt into the stock mounting holes that have been capped off from the engine bay side then allow the cable pedal to be bolted in from the inside.
Kevin
LFD Inc.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 11-07-2009, 02:25 AM   #55
bigblazerboy
bigblazerboy's Avatar
good looking build so far. also love the dog
bigblazerboy is offline   Reply With Quote
Old 11-07-2009, 01:31 PM   #56
lolife99
67-72 parts collector,…
lolife99's Avatar
Kevin,... I wish you were closer so I could get you to work on my blazer.
Excellent sheetmetal work,... like always.
Keith
Convert to disc brakes.
Old 11-07-2009, 07:58 PM   #57
my67chevytruck
Under Construction
my67chevytruck's Avatar
Great progress
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-07-2009, 09:06 PM   #58
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by Rokcrln View Post
[IMG][/IMG]
I was just looking at that ugly stock gutter this morning and considered doing something similar but with a kicked up lip at the front edge in the middle to channel water away from the distributor.
It rains too much up here to get away with what you did but it looks fantastic.
68 TT is offline   Reply With Quote
Old 11-07-2009, 11:17 PM   #59
Puropedo
I like how you did it, never seen it done like that berfore, also Im pretty sure that truck will not be seeing a lot of rain once completed
Old 11-08-2009, 12:00 AM   #60
Rokcrln
Rokcrln's Avatar
I have done a few this way it is kind of my signature on fire walls. As for rain it would not be a problem because the cowl panel has a front lip that the hood over laps so the Dizzy should never get wet. But you are right this truck will never see water. The owner has a 4 car garage with a lift as well so it will have a warm place to sleep.
Kevin
LFD Inc.
Project Lemon Drop.
Old 11-08-2009, 09:25 AM   #61
Very nice work, as always Kevin!
Old 11-08-2009, 10:16 AM   #62
hgs_notes
GEARHEAD
hgs_notes's Avatar
The spot welder only runs a few seconds at a time and probably isn't much of a draw compared to a mig or tig, or compressor for that matter.
I like the way that turned out with the spot welds. I'd guess you'll get your money back out of that welder soon enough. It will be used for more than rocker panels.
So when are you going to start selling the firewall parts pre-cut for us to start making our own patented LFD firewalls?
hgs_notes is offline   Reply With Quote
Old 11-08-2009, 01:30 PM   #63
Rokcrln
Rokcrln's Avatar
If people knew what it took to just make the two panels for doing the top edge and I tried to charge what it was worth, I would be ran off the site! I also have not found two fire walls that are close enough in shape to able to reuse my patterns, but it is well worth the finished look.
Kevin
LFD Inc.
Old 11-08-2009, 02:30 PM   #64
gcburdic
Restoration Virgin!
gcburdic's Avatar
Kevin
LFD Inc.
Kevin,
Will this work for a firewall not modified??...I'd like to use the cable style,
but don't want to fool with the firewall right now (I know 'Putter' did a write up for converting to cable style, but it involved modifying the firewall abit too)
Thanks for any info!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 11-08-2009, 03:18 PM   #65
Rokcrln
Rokcrln's Avatar
Originally Posted by gcburdic View Post
Kevin,
Yes it will work with out any mod's to the fire except the hole needed for the cable to mount and exit the firewall. I will be making a few sets of adapters to see what costs would be. I will let you all know when I am done.
Kevin
LFD Inc.
Old 11-08-2009, 03:41 PM   #66
ripdog28
ripdog28's Avatar
Incredible work. I love the firewall.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 11-08-2009, 04:21 PM   #67
VA72C10
VA72C10
VA72C10's Avatar
Looking good. Love watching your work. Now I gotta get myself back in gear on mine...
Old 11-08-2009, 08:43 PM   #68
gcburdic
Restoration Virgin!
gcburdic's Avatar
Kevin
LFD Inc.
Awesome....please let me know....I'd be interested in one! Thanks
Geoff with a G
Old 11-09-2009, 08:46 PM   #69
Rokcrln
Rokcrln's Avatar
Well I spent most of the day running around re-stocking supplies and picked up the hardware for the 67-70 gas pedal conversion and built the one for this truck as well as a few others. Costs will be $35. shipped in the USA and that gets you the adapter plate, all hardware and instructions. You will need to provide the 71-72 pedal and what ever kind of cable you want to run depending on your motor. Also the way this is set up the holes in the fire wall can be filled for a smooth look but still keep the weld nuts on the inside of the firewall for mounting. See last pic and notice the holes are filled.
This truck will use the stock 72 cable, my LowBuck truck used the 96 Impala LT1 cable or you could use Lokar or many others for a clean look. I also like the cable over the rod style because I had a truck years ago with bad mounts and it would self throttle from time to time.
Kevin
LFD Inc.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 11-11-2009, 10:08 PM   #70
ccreddell
ccreddell's Avatar
Subscribed
ccreddell is offline   Reply With Quote
Old 11-11-2009, 11:27 PM   #71
mcbassin
Still Learning
mcbassin's Avatar
Kevin, the firewall looks amazing! especially when you look at the finished product with paint. I know you have crazy skills, but approxemately how long did it take you to fab the parts and weld it in? Hours? days? a week? Keep it up!
Old 11-12-2009, 12:06 AM   #72
Rokcrln
Rokcrln's Avatar
If the owner is reading this it was weeks upon weeks What parts are you talking about? Just the top rail? The passenger side to match the drivers side? Or all the little coupons to weld up all those holes?
Kevin
LFD Inc.
Old 11-12-2009, 12:40 AM   #73
mcbassin
Still Learning
mcbassin's Avatar
I was really just referring to your signature smoothing of the drip rail around the firewall. The chamfered part if you will. thanks
Old 11-12-2009, 12:45 AM   #74
Rokcrln
Rokcrln's Avatar
Well just in making the templets, cutting the pieces out and tack welding them was about 6 hours. They have not been finish welded yet as I had a good spurt of ADD the last few days and my mind has been in a hundred other directions. I should be back on the firewall Friday.
Kevin
LFD inc.
Old 11-12-2009, 02:17 AM   #75
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice build again, as always. I really do like that firewall and I might have to try one out on my cab for my truck. That definitely helps set off the engine compartment for sure. I also love the spot welder. I would think that would knock down installation time to half or less too wouldn't it? Like asked before, would a harbor freight spot welder work for atleast the lower pinch weld? Very nice work, keep it up!
Ryan
1969 Chevy milk truck
