Old 11-07-2009, 03:02 PM   #1
gmclowsierra
5 speed
what are you guys using for a 5 speed manual trans. a friend of mine has been using a t-5 out of a 92 s10 and keeps blowing them up? any help? thanks guys.
gmclowsierra is offline   Reply With Quote
Old 11-07-2009, 03:13 PM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: 5 speed
Not surprising. The 4 and 6 cyl early T5's can be used behind a V8 with the right clutch disk, but they are weak and the output shaft is small. A V8 T5 from an F-Body will be stronger but with lots of power and heavy truck they still aren't that strong.
The only other car transmission that's stronger is a 6 speed T56. You can also have a T5 strengthened to handle lots of power. Either way, a strong manual overdrive transmission is not a cheap affair. You can step down to a Muncie or Super T10 4 speed and they will be strong and reasonably priced, but they won't have the overdrive.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-07-2009, 03:14 PM   #3
cableguy0
Re: 5 speed
theres a bunch of choices that will work and hold up its just a matter of how much you want to spend. the t5 was never intended to be used in a heavy truck with a v8. they barely held up in the s10's. the nv4500 can be found in the junkyard. theres also a bunch of aftermarket choices but they are kinda pricey.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-07-2009, 11:50 PM   #4
sierra4x4
sierra4x4's Avatar
Re: 5 speed
Another option is to use a saginaw 4 speed out of a vega or monza. Thats what I did and I ran a 2.73 axle ratio. The saginaw with 3 rings on the input shaft are geared at 1st=3.50, 2nd=2.47, 3rd=1.65, 4th=1. The gear spacing is very nice and even with the 2.73's it seemed like 3.73 of the line but like 2.73 on the highway. Alot of people say the trannys are junk but mine has held up to a mild 350 for 5 years and has even been holding up to a mild 454. With this trans 1st,2nd and 3rd aregeared very close and 4th is a little farther it feels just like a overdrive.
sierra4x4 is offline   Reply With Quote
