Old 11-09-2009, 09:38 PM   #1
Sicboy
Sicboy's Avatar
Clutch Return Spring - Saginaw to 327 - HELP???
Does it connect to the clutch fork and pull forward towards the front of the truck, or does it connect to the bell crank and pull towards the back of the truck? And where on the truck (frame) does it connect?
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482
Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!”
- Hunter S. Thompson
Sicboy is offline   Reply With Quote
Old 11-10-2009, 01:35 AM   #2
Captainfab
60-66 Nut
Re: Clutch Return Spring - Saginaw to 327 - HELP???
The spring hooks onto the clutch fork and pulls forward. The forward end of the spring hooks into a hole on the bottom flange of the frame......kinda hard to describe exactly where. If you have a factory style spring, just hook it onto the fork and stretch it a little pulling it towards the frame and you'll see the hole to hook it into.
Old 11-10-2009, 01:21 PM   #3
Sicboy
Sicboy's Avatar
Thanks.
