Old 11-10-2009, 10:42 PM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Determining 2wd or 4wd (69-72)?
What features will assist in determing if a Blazer/Jimmy is in fact a 2wd vs. 4wd?
Frame differences
VIN#
Tub differences
What do you need to look for?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-10-2009, 11:52 PM   #2
HuggerCST
HuggerCST's Avatar
Re: Determining 2wd or 4wd (69-72)?
Frame differences
VIN#
Tub differences
A front axle and driveshaft.
Sorry Nate, I couldn't resist! Ya gotta admit, you left yourself wide open for that though!
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 11-11-2009, 12:00 AM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Ok there Wynne, that's the last time I ask for assistance from you. Why don't you just go build another beautiful truck...
-Nate
Old 11-11-2009, 05:54 AM   #4
lks dcvn
lks dcvn's Avatar
2wd model key components...
frame differences - frame will be 104" wheelbase with rear coil springs with trailing arms - not leaf spring on the 4wd
VIN - will begin with a C if it is a factory 2wd. If the first digit of the VIN of the truck is a K - it was originally a 4wd.
front axle - 2wd - upper and lower arms and springs - not leaf spring straight axles like you find on a 4x4..
Tub differences - none. Except most of the 2wd Blazers I have found were rusted beyond belief...
lks dcvn is offline   Reply With Quote
Old 11-11-2009, 07:01 AM   #5
OARNGESI
OARNGESI's Avatar
Aint 2wd blazers low hump and 4wd high humps
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 11-11-2009, 07:32 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Nate,... look at the rear frame rails. They should have the same shock crossmember as your truck. Coil spring area of the frame should look the same also.
Keith
Convert to disc brakes.
Old 11-12-2009, 04:16 PM   #7
mcampbell
I think the stock 2wd engine sits about 4" forward of the 4wd. This puts the transfer case shifter in a reasonable location. I think the frames have holes for both motor mount locations but a bad conversion will still have the engine in the stock location.
mcampbell is offline   Reply With Quote
Old 11-12-2009, 05:06 PM   #8
r1lorenzini
i believe there is a dimple in the frame on the drivers side.
r1lorenzini is offline   Reply With Quote
Old 11-17-2009, 09:57 AM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks for the information guy's! I haven't been able to make it back out to look at the reason I made this thread.
As soon as I can get back out there and get some pics I will.
-Nate
