#501 | |
VA72C10
![]() Join Date: Mar 2008
Re: 1970 VA Longbed Project
Me either!
Me too ![]() Quote:
NO ![]() ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#502 |
![]() Join Date: Nov 2008
#503 |
VA72C10
Well, got the panel in today with the spacers and another panel I had made. I have a few other ideas in mind but not sure yet...
Here's the extra panels and spacers how they were packaged and the panel ![]() ![]() ![]() Here's the other idea I came up with. This panel will be installed where the factory speaker spot is (welded in flush....not overlayed). The defroster holes will be filled and round defrost outlets installed on the edges of the dash. ![]() ![]() ![]()
#504 |
VA72C10
The last pictures above showed approx how the panel will look once welded in. Covered the handle opening with electrical tape since that will be filled as well.
Got a lot done on the truck today. I didn't get over till later in the afternoon but worked late on it. Should have the front end buttoned up and on tires next time over. Got the rear all together and all bolts tightened with Loctite. Also did loctite on the front crossmember. Got the control arms put together with new ball joints pressed in the lower on Jason's shop press. Installed the new upper ball joints and the new cross shafts and bushings in all. Got upper and lower arms installed. Installed the steering box for the final time. Got to get some shorter bolts for my airbags and then will mount those, measure for and drill the holes in the lower control arm plates, and then put the spindles on. Figured I'd start off by showing how nice the factory brake lines look after being cleaned up ![]() Here's the parts I worked on installing today.... ![]() Here's the suspension parts for the passenger front ![]() Here's the calipers taped up ready for paint ![]() And painted with gloss black ceramic caliper paint to match the rear calipers ![]()
#505 |
VA72C10
Here are the pictures of the upper A-arms in case anyone is planning to install these. Fairly straightforward and the easiest thing I did today
#506 |
VA72C10
Finished up the rear trailing arms. All that's left on the rear is to drill the bolt and fitting holes for the airbags now that I have their final location set.
![]() ![]() Not sure how this will show but trying to show how I put red loctite on all the bolts to make sure they stay put! ![]() Here's the spacers installed. They fit great ![]() ![]()
#507 |
VA72C10
Here's the front end all together
#508 |
VA72C10
Well, not all together
![]() Here's the front driprail progress ![]() ![]() He worked on it some while I was there ![]() Got the entire front welded up. Just needs to be ground down now... ![]() ![]() Got the cab back upright as you can see...that was interesting ![]() But no damage and it looks good. Probably won't be quite this low but close.... ![]()
#509 |
Not a bad idea huh?
#510 |
VA72C10
#511 |
i am new to blogging and am not sure how to post an original question. please help. thanks.
#512 |
not putting down your idea but if you put the panel where the speaker grill is you'll get a backwards "chevrolet" on your windshield. it won't be a bad thing if you don't mind it but i know it would bug me. just a thought.
Tail gate looks great though!
69' 1/2 ton LONGBED__ _______ |__\__ |__(O)______(O)] ![]() My build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=354115 |
#513 |
Moderator
![]() Join Date: May 2007
Lookin good!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#514 |
Still Learning
Great progress! looks like a hard days work. I like the tailgate insert! Where did you purchase the front suspension parts? Just a local part house? I need all the same components and don't want to shell out a bunch of $$$. Keep up the good work!
#515 | |||
VA72C10
![]() Quote:
It was all CPP stuff. Saw a kit on sale on ebay and added the cross shaft kits and the custom pedals, braided brake hoses, and adjustable prop valve to it and made me a package deal. Couldn't pass it up...even though next time I'd check with ECE first to see if they could price match because it took a month to get the parts. (backordered even though they told me it was in stock when I called the order in)
#516 |
Now what??
You have some very nice ideas. I like the filler panel on the dash.. kinda what I had in mind, well, your idea is MUCH cooler than mine ... The front suspension looks great! Keep up the work..
69 Long Fleet - Project 06 Ram 1ton Cummins 4x4-DD 01 Tahoe- wifes "The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi "A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell my, um, build ![]() ![]() ![]() Last edited by 0331grunt; 11-16-2009 at 11:26 AM. |
#517 |
Restoration Virgin!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#518 | ||
VA72C10
![]() Quote:
#519 |
Looking good! How thick are those spacers for the trailing arms?
#520 |
VA72C10
They are 1/2" thick aluminum. Centers the rear nicely in the notch and the rear fenderwells when fully dropped.
#521 |
Spanked once
![]() Join Date: Oct 2006
Sorry I'm late joining in on your fun and first thing is ...This is great the way you keep up with it and the truck. I'm in the process now of putting my bear claw latches and plan on putting the claws in the the pillar ,wasn't sure if you had come up with a plan on this or not. I think this will give me more space and less hassle in the door. I,m going to shave the door and jam and put it a little lower than the stock position. HTH
The ole 350 budget build. |
#522 |
Under Construction
looking good Jonathan!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#523 | |
VA72C10
![]() I'm going with mine in the doors just for the smooth look on the pillar. I'm shaving everything on the pillar including the recess for the spring that I believe was for the jack originally and of course the stock latch area. Probably will be going lower than the stock position. Getting polished stainless striker to go on the jamb.
#524 |
VA72C10
Thanks!
Went over tonight and piddled around for a bit. Had no energy for some reason. Got the driver's bag mocked up and marked the drilling spot (had to search for shorter bolts since I forgot to bring that bag with me) Got the sway bar brackets painted, had to touch up the calipers as I missed an area Saturday. Also torqued down the upper and lower control arm shafts. Played with the rear brake lines, and mocked up the shocks to see what I need to buy to install them which is just the lower bolts. Going to paint the shocks to match the body. The engine, tranny, driveshaft, and shocks will be body color. Think it will be a nice pop of color with the otherwise silver and black theme going on w/ the chassis. Mainly though tonight I made a list of airbag fittings and bolts I need still, and watched Jason finish a motor swap in a sebring. Just not a motivated evening, but as I left to help my brother in law move 180 studs off a truck and into his basement ![]() ![]() ![]()
#525 |
can't believe I haven't subscribed to this one yet. going a few steps beyond sane I see. Hahaha. I love it!
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 |
