Old 11-13-2009, 11:22 PM   #1
bluesfella
bluesfella's Avatar
Easiest way to remove a rocker panel?
The donor truck I bought has a pretty good rocker/rear floor area, so I'd like to cut it out and prep it to go in my truck.
What's the best method for removing it? Should I cut it out as one piece, pull off the outer rocker first, etc?
I want to remove this area:
www.vancerutherford.com
bluesfella is offline   Reply With Quote
Old 11-13-2009, 11:42 PM   #2
Bugeyev8
Bugeyev8's Avatar
Re: Easiest way to remove a rocker panel?
just order a new one, they are only 40$ and chances are by the time you remove it...you will find other issues with it
Bugeyev8 is offline   Reply With Quote
Old 11-14-2009, 12:22 AM   #3
bluesfella
bluesfella's Avatar
Just had a new baby that spent a week in the hospital - ZERO funds for buying patch panels at the moment. This is a truck I'm parting out to pay for stuff like this, but I'm not making much...and this part is about the only usable part in the cab. So, I might as well use it.
There's a little rust through, but only in very simple, flat areas that I can repair. I'd like to use this piece if I possibly can. If I ruin it cutting it out, or there turns out to be more rust that what's visible, I may chunk it and save up for a patch panel. But it couldn't hurt to try, right?
Old 11-14-2009, 01:00 AM   #4
Captainfab
60-66 Nut
IMO the correct way would be to drill out all the spot welds and remove the outer rocker first, and then remove the rest of the area you want. This would be basically the reverse of how it went together.
I hope the new baby is doing well......
Old 11-14-2009, 01:43 AM   #5
chevytrucknut61
chevytrucknut61's Avatar
Thats how I replaced mine drilled out the spotwelds but I had new ones to replace them with. I did replace part of the floor area that is outlined but only on passenger side
chevytrucknut61 is offline   Reply With Quote
