Old 11-15-2009, 06:53 PM   #26
Chuck78
Re: Replacing the clutch on a 1960 GMC, SM-318
Also found a shop here in town that shortens driveshafts for a really reasonable $65, and around $125 I think for aluminum (no warranty on aluminum mods on used shafts). They'll custom build a new driveshaft for you for $250 in steel and $400-$500 range for aluminum. Columbus Joint and Clutch. Then I just need to get the dial indicator to measure if I have any runout from my crank centerline to the bellhousing register for the transmission input bearing retainer, fab up a rear trans crossmember, and then get a speedometer adapter for the Tremec from the ford style to GM cable.
Chuck in Ohio
*1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end
*1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project
*Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc
Chuck78 is offline   Reply With Quote
Old 11-15-2009, 07:30 PM   #27
justcuz
justcuz's Avatar
Got you on the stability. Great that you found those other resources.
justcuz is offline   Reply With Quote
Old 09-24-2016, 10:00 PM   #28
layingC10nK5
Hey guys I'm helping a friend with his clutch on the same rare 305 v6 and we got the same wrong parts. Can you guys tell me what you ended up using. I cant find anything that works. Thanks.
layingC10nK5 is offline   Reply With Quote
Old 09-25-2016, 07:45 AM   #29
Chuck78
If you search 6066GMCclub.com, you'll find that the AMS Rhinopac 04-528 is the one to use. Don't use the Perfection brand that fits most of the same applications, as it will not fit the gmc. Use this brand only. Or just get the original clutch and pressure plate remanufactured. Hite Parts Exchange did an excellent job remanufacturing mine.
Chuck in Ohio
Old 09-25-2016, 11:13 AM   #30
TJ's Chevy
TJ's Chevy's Avatar
Just did this folks. The AMS Clutch kit has the Same issue the rest do. But the nub on the flywheel side is not quite as tall. You will find that machining it down provides better results. Ask me how I know. Everything else is perfect except the disc. Also be aware that the clutch fork and throw out bearing have to also be in while you install the trans. Unless you have someway of collapsing the fingers. Due to the stupid small bell housing design Nothing is somewhat easy to install. But when done the results are nice.
Old 09-25-2016, 09:06 PM   #31
layingC10nK5
Thanks guys. Unfortunately the shop that rebuilt the engine tossed out all the clutch parts and gave us new parts that dont fit. Now we're blindly trying different parts to see what works.
Old 09-25-2016, 09:39 PM   #32
padresag
someone should have some cores that you can get rebuilt. you might ask over on the GMC site. ther should be 305s sitting around that still have clutches on them.
it is the chevy bellhousing mounts that you can use
ron
padresag is offline   Reply With Quote
Old 09-25-2016, 11:46 PM   #33
TJ's Chevy
TJ's Chevy's Avatar
You can get an AMS disc and then machine the nub down and it should work. Though I would recommend the whole kit so you have everything from one place. If I hadn't thrown my old disc away you could have had it for a rebuilable core, but I really don't know if it was rebuildable! haha It was pretty toasty.
Old 09-25-2016, 11:56 PM   #34
padresag
I always like the positiveness of the word "should"
ron
Old 09-26-2016, 12:45 AM   #35
TJ's Chevy
TJ's Chevy's Avatar
ron
Guaranteeing is a dangerous thing. Worked for me...Should work for him. But I will not be the one to say it Will work for him.
Old 09-26-2016, 07:30 PM   #36
padresag
I found a used clutch set if you are interested.the shop in the yard next to me has one. I got the engine him a few years back in case he ever needed another for his fork lift. A freind of mine had it before and put in a 350 with 4500 trans. he doesn't need the clutch as the forklift uses a different setup
ron
Old 09-26-2016, 09:57 PM   #37
layingC10nK5
Thanks for all the help guys. We ordered the kit already. Hopefully we get done with this and sit the motor in soon.
Old 06-01-2020, 08:56 PM   #38
KIC
1960 GMC Burb
KIC's Avatar
Going through the same with my 60 GMC .. This was really helpful.... I am waiting for a disc part number from a shop that actually solved this for a client a year or so ago... If I get it I will post it...
1960 GMC Suburban
1/2 ton V-6
2nd generation original owner
60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban
60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs
2003 Tahoe LT
KIC is offline   Reply With Quote
Old 09-01-2020, 08:33 PM   #39
Corts60
Just here to tinker
Corts60's Avatar
Glad this thread is still alive and helping people out!
Old 09-14-2022, 09:18 PM   #40
D'Monsta
D'Monsta's Avatar
I'll be doing my clutch disc this weekend.. Glad I found this thread..
D'Monsta is offline   Reply With Quote
