11-15-2009, 10:11 PM | #1 |
a space saver work bench
here's what i installed on the wall of the shop. it's a 3'x7' solid wood door with a lexon tuff top. this is attach to a hinged to a 2x4 that is lag bolted to the wall studs. folded down work hight is 36". there is two free hinged angle iron legs mounted to the under side of the door that free swing under there own weight as the door is moveing from the up to the work position giving the bench it's support. to put the work bench back out of the way i just lift the bench up till it's vertical and the legs move with the bench then the latch locks and holds it secure it it's storage position. the 2nd work top is 48" wide and 22" deep. it to is hinge to the under side of the fold up bench useing loom cover chain to hold it in the horizontal position. there is a fix mount light behind the small tool storage shelf for the 2'x4' work top. i added this as a extra smaller bench as when a truck is in the bay. the main 3'x7' bench is to tight to work around. i also ran a power cord to the outside edge of the bench for power tools. i think that 800 lbs would not be to much of a load for the main bench. the small 2x4 top will hold 80 lbs. the nice thing about this it out of the way till i need it and when i need it it's clean and ready to go at a moments notice.
Trueman Last edited by 463; 11-18-2009 at 07:55 PM. |
11-15-2009, 11:21 PM | #2 |
Luv the Crewcabs
Re: a space saver work bench
Good Job, Thanks for Sharing......
I like the Fact that it would always be Clean to work on , Fixed location work tables always seem to become a catch all Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
11-17-2009, 02:33 AM | #3 |
That is an awesome idea. Well done!
11-17-2009, 07:23 PM | #4 |
Cut a big hole in the wall and it will be self cleaning.
11-17-2009, 09:30 PM | #5 |
isn't that just nifty. nice work.
69 4wd V6 20k orig miles!! 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
11-18-2009, 01:19 PM | #6 |
Sweet Idea, I might just benchmark it from you.....
As they say imatation is the most sincere form of flattery....
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB |
11-28-2009, 12:12 AM | #7 |
My problem is I would never be able to fold it back up. I can't find the top of my workbench now. Good idea though. I like it.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
