#276 |
Low & Fast!
Re: 78 2wd Blazer build
Well, here is my new project.. 2door 2wd Tahoe. I told my wife it is going to be my new trash truck.. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=353050
#277 |
clear headlights remove roofrail and most of the chrome trim on the sides different sidemirrors sand the doorhandles smooth and paint them in the bodycolour make a set of foglights in the frontbumper again hmmmmmm you could do a lot of the same stuff to it you did to the blazer
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#278 | |
Still plays with trucks
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#279 |
![]() Join Date: Jul 2009
And you have got to get rid of the tire tread trim running down the sides. That stuff is a bear to get off, but once it is off, it makes a world of difference.
#280 | |
You can get the clean bumpers without the rubber strip on them too. It really cleans up the look of the rig.
#281 | |
it makes a big mess but does remove the stickers without harming the paint
#282 |
Yep! I used an "Eraser" wheel on my old '94. It leaves behind a bunch of booger lookin' stuff, but washes right off. It worked great.
#283 |
Low & Fast!
I took all the trim off of it the day after I got it. Here it a pic of it as it looks today and I do have a build link for right here..
http://67-72chevytrucks.com/vboard/s...d.php?t=353050 Trav
#284 |
C10 Club Tennessee
Why is that thing that far off the ground??? What are you waiting for???
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
#285 |
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#286 |
Low & Fast!
Man that just not right.
#287 |
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() Last edited by menace121978; 11-21-2009 at 11:32 AM. |
#288 |
its allready starting to look good maibe some blackened rearlights and clear headlights and indicatorlights
i've seen someone take the clearcoat of his stock aloys and use rubbing compound and an electric hand held buffingmachine to get the wheels shiny like chrome he did say he would never do it again though since it was a hell of a job to do anything planned on the engine?
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 11-21-2009 at 03:32 PM. |
#289 | |
Low & Fast!
#290 |
Tot Roddin'
I'll have to check out the new project Travis, nice buy!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#291 |
Awesome Blazer tvblazer78, I just bought an 82 2wd Blazer last month. Looking at yours it gives me lots of ideas.
I see you installed a steering damper on yours. Did this make a difference in the steering, I haven’t seen too many on 2wd’s. |
#292 |
been reading some interesting stuff with a project called "the grenade" on some turboforum
the guy blew up a big dollar engine and just for giggles is now using a stock 350 engine with a cam he found somewhere 2 stock T3 turbo's out of a buick mounted to some tubulair manifolds he migwelded an mega squirt injection on a basicly stock tpi intake and a 50 schot of nitrous at 3000 rpm . the total tread is about 150 pages long where i am now he actually drove this setup with a if it breaks it breaks state of mind on the track to 9.89 in a 3500 pound 3th gen firebird using semy slicks and a build turbo 400 with a trucktype B&M converter and its still together the car tested about 600 some hp and even more torq on the dyno he never touched the engine itself other than check the oilfilter for particles and taking the heads off to check the valve seats and de gap on the toprings wish needed to be big to prevent them from butting its a 2 bolt cast everything and the blowby is tremendous hes running 22 pounds of boost on a normal headgasket and isnt using any ARP stuff. now this might be a bit over the top for youre project but i think the T3 part is interesting there comming ontoo boost at about 3000 rpm meaning there kindah small for racingpurposes but verry nice on the street , you might not even need a STS setup in the future but build one youreself on a budget , the parts needed to rebuild these turbos are about 60 bucks and the turbos somewhere between 25 and 125 bucks at the junkyard im not behind my laptop right now but i give you the link later on if times get better again for me i like to go that route on a 305 i have in an older truck , i will put an enginedaiper under it though before taking it to the track
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 12-16-2009 at 09:56 AM. |
#293 |
http://www.theturboforums.com/smf/index.php?topic=61219.0[/url] here you go
[url] i been reading on and found a movie from the testing
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 12-16-2009 at 10:00 AM. |
#294 | |
Low & Fast!
Trav
#295 | |
Low & Fast!
#296 |
Low & Fast!
Jim85IROC,
Hope this pic works for you. If you need any more just let me know. Trav
#297 | |
Sunburst C10!!!
Gage 1967 C10 Shortbed Stepside |
#298 | |
I'd appreciate it! Thanks --Jim |
#299 | |
Low & Fast!
Later, Trav
#300 | |
PITbut
Beautiful truck.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! ![]() My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
