Old 11-17-2009, 08:46 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Linelock?
Who makes a linelock kit for our trucks?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 11-17-2009, 08:49 PM   #2
Scootin 81 C20
3/4 Ton Rodder
Scootin 81 C20's Avatar
Re: Linelock?
I know that I should know this, but what is a linelock?
1981 Chevy Scottsdale C20 "Orange Crush": SOLD
1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy.
Scootin 81 C20 is offline   Reply With Quote
Old 11-17-2009, 08:49 PM   #3
bigblock73
yeller
bigblock73's Avatar
Re: Linelock?
Hurst
But they are not "made for 73-87's", they are universal kits.
bigblock73 is offline   Reply With Quote
Old 11-17-2009, 09:07 PM   #4
thirdstreettito
Resident of Here
Re: Linelock?
How do they install/work?
Scootin 81 - A linelock is when the front brakes are depressed only, drag racers use em for burnouts.
~Bradley~
Miss having a truck
Old 11-17-2009, 09:09 PM   #5
Scootin 81 C20
3/4 Ton Rodder
Re: Linelock?
Ok, I had a dumb a$$ attack and couldn't remember what they were.
Old 11-17-2009, 09:11 PM   #6
sailed2japan
Jonny
sailed2japan's Avatar
Re: Linelock?
It's basically an electric valve you put in the brake line. You can install them one of two way.
1: Place it on the line to the front so you can press the brake then hit the switch to prevent the pressure from returning to the Master cylinder.
2: Place it in line with the rear so you can turn it on and direct pressure only to the front wheels.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 11-17-2009, 09:44 PM   #7
CoggedBelt75
CoggedBelt75's Avatar
Re: Linelock?
Here is mine. It is a rebuildable Biondo line lock
Since I still use a column shifter, I mounted things within reach. The first one is a fuel shut off, the middle is for the line lock, and the third is for the trans brake.
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 11-17-2009, 10:51 PM   #8
thirdstreettito
Resident of Here
Re: Linelock?
What do you do? Just hook it up to a powered on/off switch?
~Bradley~
Miss having a truck
Old 11-17-2009, 11:05 PM   #9
3r!c84
Badass
3r!c84's Avatar
Re: Linelock?
yes all it is,is holding the brake pressure in the brake lines,so you pump up the brakes hit the linelock switch and let your foot off the brake to do a burnout,and you can hit the switch right befor your done and roll forward.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-18-2009, 12:19 AM   #10
Scootin 81 C20
3/4 Ton Rodder
Re: Linelock?
Would installing a linelock on a non-posi truck allow it to do a posi style burnout since the rear brakes wouldn't be on?
Old 11-18-2009, 12:24 AM   #11
thirdstreettito
Resident of Here
Re: Linelock?
No. An open diff truck (non posi) spins the right rear tire because that is where the torque goes down to. Linelock doesnt change the way the torque goes.
~Bradley~
Miss having a truck
Old 11-18-2009, 12:29 AM   #12
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: Linelock?
i have one i found for 40 bucks on craigslist
it works good
its just a universal and i made my own lines
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 11-18-2009, 12:37 AM   #13
Scootin 81 C20
3/4 Ton Rodder
Re: Linelock?
That's weird. My truck spins the left rear while the right rear catches traction. Why?!?!?!
Old 11-18-2009, 12:53 AM   #14
3r!c84
Badass
3r!c84's Avatar
Re: Linelock?
right side got more weight ? mine with a full tank of gas spins the right side tire,but when its low it spings my left
-00 Saturn 5spd
1/4:13:90
Old 11-18-2009, 02:47 AM   #15
mongoose
mongoose's Avatar
Re: Linelock?
that doesn't always work... i know my hurst was more of a one way valve.. you could pump pressure into it even though it's on but it wont come back out.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 11-18-2009, 07:16 PM   #16
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: Linelock?
it could be your brakes on the right side they might be too tight
back them off and see what happens
Gage
Old 11-18-2009, 07:18 PM   #17
Scootin 81 C20
3/4 Ton Rodder
Re: Linelock?
Ok, I'll try that. I wouldn't think it's weight because the only thing on that side is my spare tire and that wouldn't be that much of a difference. So maybe if I back that off, I may have posi?
Old 11-18-2009, 07:25 PM   #18
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: Linelock?
no your right wheel will spin instead of your left one
thats what mine did when i had an open diff
Gage
Old 11-18-2009, 07:29 PM   #19
Scootin 81 C20
3/4 Ton Rodder
Re: Linelock?
Ok, how can I tell if I have a limited slip or open diff?
Old 11-18-2009, 07:33 PM   #20
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: Linelock?
if they dont both spin now i dont think its a posi
but you could try backing off the brakes
Gage
Old 11-18-2009, 07:44 PM   #21
3r!c84
Badass
3r!c84's Avatar
Re: Linelock?
it wouldnt be a posi if only one wheel was spining with or without the brake drag
-00 Saturn 5spd
1/4:13:90
Old 11-18-2009, 11:51 PM   #22
Scootin 81 C20
3/4 Ton Rodder
Re: Linelock?
Ok, thanks.
