Old 11-19-2009, 01:13 PM   #1
vegaschevy
rag joint replacement
Do these wear out much? what happens when they do?
vegaschevy is offline   Reply With Quote
Old 11-19-2009, 01:23 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: rag joint replacement
The rubber deteriorates over time with exposure to heat, oil, etc. It can cause slop in your steering when it gets worn. I just rebuilt mine. Cheap and easy. Click on my build link for pics/description. I also replaced the input (steering) shaft seal, and output (pitman) shaft seal on the power steering box at the same time.
You can purchase a complete ragjoint if the splines are worn on your original for around $50, or just replace the rubber disc for around $10 with a rebuild kit from a parts store.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-19-2009, 03:57 PM   #3
vegaschevy
Ill be sure to check mine out and see what she looks like. My steering is not precise but it definitely is not very sloppy. Seems as though it is just worn.
Old 11-19-2009, 04:42 PM   #4
mclairmo
I used the parts store rebuild kit and it has lasted over 15 years. Not hard to do. Saves you some cash versus buying an all new joint.
mclairmo is offline   Reply With Quote
