Old 11-21-2009, 07:51 PM   #1
1-PU70
1-PU70's Avatar
Hydroboost
Are there any posts of a hydroboost conversion using junk yard parts like doner vehicles and install mods. I did a search and searched the google and came up blank. I think it would be a good up grade for my towing.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 11-21-2009, 08:34 PM   #2
eric67m
eric67m's Avatar
Re: Hydroboost
I would be interested in this info also. I posted a "who is running hydroboost" on the 4x4 page. I think It sounds like a good upgrade and will be saving my pennies and dimes to do it some day.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 11-21-2009, 08:51 PM   #3
greens69
greens69's Avatar
Re: Hydroboost
I just put a hydroboost system on my 59 Wagon and I used a hydroboost from the auto parts from a 95 Astro Van, and I found the rest of the parts needed from TallonHydraulics.com for the hose kit,spring,rod and retainer and all the fittings. The outcome was great and I am really happy I went this route.
Houston and Dallas Autorama Show Chairman
///Relaxed Atmosphere
1969 Chevrolet C10
1972 Chevrolet 2WD Blazer
1987 GMC Sierra
greens69 is offline   Reply With Quote
Old 11-21-2009, 08:58 PM   #4
100%Chevy
Re: Hydroboost
I have hydroboost on my 87,G-30 motorhome and my 95,K-3500.
Also just pulled a unit from a 89 motorhome.
Why do people want to use this brake system on their vehicles?
Surely it's only better on heavier vehicles.But why use it on light duty stuff?
Mike.
100%Chevy is offline   Reply With Quote
Old 11-21-2009, 09:04 PM   #5
greens69
greens69's Avatar
Re: Hydroboost
The reason I went with it on my wagon was the for the space, it had 7" booster and the brakes were terrible.... and I couldn't go bigger with the big block for clearance issues, so went this way and I couldn't be happier.
1969 Chevrolet C10
1987 GMC Sierra
Old 11-21-2009, 09:05 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Hydroboost
This will get you some basics
http://www.thehollisterroadcompany.com/hydroboost.html
search this site for one done on a early 70's truck
Old 11-22-2009, 02:36 AM   #7
mosesburb
I had a V-8
mosesburb's Avatar
Re: Hydroboost
I did one on my '72 Suburban. The nuts and bolts of the swap are fairly easy/straightforward, but the hoses can be a hoot. I like the mounting plate from the 88-99 C/K trucks because it is very easy to adapt and very clean looking when finished.
If you are super bored there is a link in my sig to the whole thread, but if you would rather spend your time more productively, this is a link to the post in the thread regarding the hydroboost unit.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 11-22-2009, 10:21 AM   #8
eric67m
eric67m's Avatar
Re: Hydroboost
4x4 guys use them because larger tires with stock brakes are not as powerful as necessary.
What years used them. I know diesels did, but it seems like they were used from the 70's-2000's. I know mainly the heavier duty rigs but it also sounds like some 1/2 tons and vans used it.
Old 11-22-2009, 11:43 AM   #9
Wrenchbender Ret
Re: Hydroboost
Practically every Chev/GMC 1 ton truck from 74 up had it.
Wrenchbender Ret is offline   Reply With Quote
Old 11-22-2009, 12:25 PM   #10
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: Hydroboost
Also helps if you are running BIG camshafts,No low vacuum problems.Early diesel pickups that the company I work for had hydro boost (1/2 tons)
powerdriver 1958 is offline   Reply With Quote
Old 11-22-2009, 02:21 PM   #11
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: Hydroboost
From the research I have done it looks like '79 is the last year to use lines with inverted flare connections, like our old trucks. '80 and newer use metric connections with o- rings. So it looks like if you don't want to end up fabbing hybrid lines, stay with the '79 and older. Looking thru O'Reillys listings, they give the measurements on the lines. I wondered what was available to make work, so I looked up a '78 C30 with a 454, a '78 C30 with a 350, and a '78 C10 with the Olds 5.7 Diesel. All 3 are different lengths, and are available cheap.
So my thinking is once you figure out the mounting, measure up for lines & pick what fits. Or, like some stores are good about... just order them all, use what fits best then return the rest.
And if you aren't crazy about the fab work, just get out your wallet:
http://www.performanceonline.com/sto...cat=342&page=1
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 11-22-2009, 02:30 PM   #12
BigChevy80
BigChevy80's Avatar
Re: Hydroboost
Any GM vehicle from the 70's and 80's with a diesel had hydroboost. Also some of the bigger GM station wagons used them. Once you drive a vehicle with hydroboost, you will know why people like them...
-Tony
Money is no object... once it's in your wife's hands.
1972 GMC Sierra
1977 Ford LTD II
2000 Pontiac Grand Prix (wife's ride)
BigChevy80 is offline   Reply With Quote
Old 11-22-2009, 02:45 PM   #13
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: Hydroboost
Here's the 3 different "pump to Hydroboost" hoses I came up with just on the '78 "C" series. I'm sure if we looked at the G30 van, P30, diesel cars, etc. we would find more.
Old 11-22-2009, 02:48 PM   #14
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: Hydroboost
And the "Hydroboost to steering gear" that fit all 3 applications
Old 11-22-2009, 03:02 PM   #15
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: Hydroboost
While I'm at it, might as well keep going
'79 Olds 98 diesel. No measurement available on the pump hose.
Old 11-22-2009, 03:10 PM   #16
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: Hydroboost
'79 P30 with a 350 gas. Pump, then gear:
Old 11-22-2009, 03:14 PM   #17
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: Hydroboost
That pretty much finishes out the list (from most popular on down) of what I feel might fit good, is available now and 10 years from now when you need a replacement. It wouldn't be fun to blow a hose in the middle of nowhere and then find out what you used is obsolete. While lines can be made, you can't just get them everywhere.
Old 11-22-2009, 04:13 PM   #18
BigChevy80
BigChevy80's Avatar
Re: Hydroboost
Alot of machine shops and old style service stations can custom make hydraulic hoses. If you can find one that has the right fittings, you can get them custom made. I had some power steering lines made this way a few years ago.
-Tony
1972 GMC Sierra
1977 Ford LTD II
Old 11-22-2009, 04:58 PM   #19
wildwilly4x4
Re: Hydroboost
On my 72 I mounted a hydroboost since I am running a 6.5 diesel. Line the 80's bracket up with the middle two holes in the bracket to the two studs right next to the hole in your firewall. Mark the top mounting studs location on the bracket and drill the new top new stud holes in the bracket (7/17 IIRC). Then you will need to trim the top and bottom of the bracket to make it fit correctly. You may have to lengthen the brake pedal pushrod as well, I had to anyways. This is a very easy mod, but as previosly stated you will either need hose adapters, custom hoses, or do as I did and use the stock hoses. You can change the power steering pump's discharge fitting to the later O-ring style, and then use a late 70's-80's steering box. Somtimes that route may be cheaper if you have some decent wrecking yards or buddys around. Good luck!
wildwilly4x4 is offline   Reply With Quote
Old 05-08-2013, 12:01 PM   #20
bugmasta
bugmasta's Avatar
Re: Hydroboost
Subscribed.
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 06-26-2013, 12:25 AM   #21
Rusty69
Re: Hydroboost
Which hydroboost unit is easiest to mount to a 69 firewall? I'm trying to go all metric fittings. I've seen some guys say a 95 Astros and others say a 99 c3500. Just curious which stock mounting bracket takes the least massaging to make fit. My buddy works at the industrial John Deere shop, so luckily hoses are the least of my worries. Any info would be great.
Rusty69 is offline   Reply With Quote
Old 06-27-2013, 10:59 PM   #22
Murphy IRE
Re: Hydroboost
I put in a Hydro boost from ABS in Orange Cal. It was one of the easier thingsI've done. Two small modifications on the return line and that was it.
The thread was "Wow after everything, I finally have brakes. i couldn't find one used and in the mountains, i went with new.
Murphy IRE is offline   Reply With Quote
Old 06-28-2013, 01:21 AM   #23
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Hydroboost
I put Hydroboost on my '67 C-30 diesel dually. I had too notch the mounting plate and extend the rod, but it was very straight forward. I used the steering box out the truck that hydroboost unit came from, so I had line fitment issues. Here's the few pics I have of it.
http://67-72chevytrucks.com/vboard/s...254096&page=12
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-28-2013, 07:21 PM   #24
allons
Re: Hydroboost
I'm planning on using the hydroboost system on the build of my '72 C10. Also, I'm planning on running the HB for the brakes AND the power steering. The difference is the plan is to run a Mercedes Benz electric hydraulic pump to feed both the brakes and the steering thereby freeing up some HP that would have been used to drive the hydraulic pump. At least that's the plan!
Sign me up for this thread!
allons is offline   Reply With Quote
Old 06-28-2013, 10:32 PM   #25
HarleyT
Re: Hydroboost
I'm in the process of doing this right now,ill get a list of parts I used and post them next week . I am currently waiting on the hydro boost fittings to convert to -6 lines
HarleyT is offline   Reply With Quote
