Old 11-22-2009, 05:33 PM   #1
americanmusc1e
americanmusc1e's Avatar
removing rearend on a 69 c10????
I'm removing the rearend off of our '69 parts truck to put on my '70. I have it all loose, I have the 4 (two per side) big nuts off of the U-bolts, but the rearend is still stuck on the trailing arms and it doesn't want to come off.
how hard should it be to remove it?????
any tips???? I tried searching but found nothing
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 11-22-2009, 05:57 PM   #2
Wrenchbender Ret
Re: removing rearend on a 69 c10????
The u-bolts are usually rusted inside the arm. Hit them with a big hammer. You will want to replace them anyhow. Sometimes you have to put some heat to them.
Wrenchbender Ret is offline   Reply With Quote
Old 11-22-2009, 06:03 PM   #3
rwolf9653
more ideas than money
rwolf9653's Avatar
Spray with your favortie penetrating oil.....hit with a BFH......repeat as necessary.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 11-22-2009, 06:16 PM   #4
Boog
laying low
Boog's Avatar
Yeah they dont' give up so easy after 40 years. Stay with it you will get it. You could always use the hot wrench on the bolts. Cut those suckers.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-22-2009, 08:07 PM   #5
americanmusc1e
that's basically what we did, and we finally got 'em out!!!!
I pulled the cover and the oil looks brand new, the truck has been sitting for over 10 years. The truck has a 3.07 open diff, the same thing I already had. I wish I had the money to switch it out to a 3.73 posi.
ever use SOK penetrating oil in the green can!!!! it works every time, that and a 12# sledge hammer and a 36" crowbar
-- Josh
