Old 11-24-2009, 04:16 AM   #26
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: wood floor installed pictures
Originally Posted by squirel View Post
I really do not know if there is any difference in the amount of cross braces between long and short bed but somebody on here will know
As far as I can tell from my catalog, Longbeds have 7 cross braces and shortbeds have 6.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 11-25-2009, 09:09 AM   #27
Dan in Pasadena
Dan in Pasadena's Avatar
Dan in Pasadena I have a carpenter buddy that swears by Varathane diamond wood finish outdoor with UV protection he uses it on everything. So Used that so if it fails I can blame him lol. I also used varathane wood stain.
Thanks squirel. I recently used some Varathane interior poly that is water based (believe it or not) and it came out great. It was SO easy to sand and re-coat fast that I laid about six satin coats on my fireplace mantel. I'm sure the stuff you used isn't water based but good to know, thanks again
Dan in Pasadena is offline   Reply With Quote
Old 11-25-2009, 09:28 AM   #28
68_Step
Wow... that looks fantastic! Since wood moves with the seasons, will you have to re-tighten the bolts/screws again? Lock nuts?
68_Step is offline   Reply With Quote
Old 11-25-2009, 10:13 AM   #29
Don Brace
Active Member
Over the past couple of years I have restored two 1971 Longhorns. One is painted red with a cedar bed that I made using a table saw and router. The other is painted yellow with a red oak bed. The oak bed I bought from Mar-K and it fit perfect. It is well worth the money to me. The red truck with the cedar bed is my driver. I finished it two years ago. Both beds are finished with Min-Wax Helsmans spar urathane. The finish on this truck is flaking off. I would recomend you do not use this. Theyellow truck I do not drive very often and am hesitant to do so becaure I fear the finish will also flake off. Both beds I put natural stain on and then ten coats of Min-Wax on all sides of the boards sanding between each coat. I chose cedar for the driver because cedar holds up well here in Minnesota and was very affordable. About 100 dollars for the wood.
Don Brace MN
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
61 Impala CVRT 409 4 SP
2- 71 Longhorns
Always looking for old toy trains, Juke boxes Pin ball and game machines.
Don Brace is offline   Reply With Quote
Old 11-25-2009, 12:16 PM   #30
squirel
squirel's Avatar
Dan in Pasadena: I am at work right now but I am sure that it is water based I will check when I get home
68_Step: Good call on having to re-tighten the bolts. I did use a stainless bolt kit and it came with the lock washers
Don Brace: I hope the Varathane holds up I will be only driving the truck in the summer. I am actually building the truck to pull my holiday trailer
In some foreign language "merge" means to stop and turn your head left.
My build page
http://67chev.shawwebspace.ca/
squirel is offline   Reply With Quote
Old 11-25-2009, 12:59 PM   #31
Dan in Pasadena
Squirel,
If that Varathane Diamond finish stuff is water based, yoo hoo! As it happens, I am going to be refinishing my patio sliding wood doors (probably over this long weekend). I'll pick up some of that Diamond finish and try it out. These doors are outside but under a shade structure so they don't get much direct sun and they're on the east side of the house so they really only get the cooler morning sun. They'll be a great test ground for using it later on my bed wood cause; like you, I intend my truck to be aweekend driver. I'll have a piece of carpet over it and a car cover over it most of the time.
Old 11-25-2009, 01:46 PM   #32
msgross
msgross's Avatar
Originally Posted by Mayo View Post
Very nice. My truck could use a new wood floor(I got plywood screwed to the original wood right now) but I am afraid it would be too nice and I would ruin it by hauling stuff. Another reason I haven't done the wood in my truck is the price. Those kits seem pretty expensive, does anyone know how much cheaper it is if you buy lumber and cut it to fit yourself?
nice bed...
you can go to www.gmcpauls.com and get all the measurements for the bed wood. Even shows the proper groove. I've seen pressure treated decking used for beater trucks...
my cabinet guy quoted $330 for the oak all cut to spec...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-25-2009, 02:00 PM   #33
CPNE
Resident Curmudgeon
CPNE's Avatar
Originally Posted by thelonerife View Post
I'll be getting a bed delivered in pieces Tues. that has longbed cross sills. I see the 1st pic that has them installed. Is that all of them that is required?
No, there are at least 2 more cross sills required for a longbed
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 11-25-2009, 02:55 PM   #34
Mayo
Cool Truck
Mayo's Avatar
Originally Posted by msgross View Post
nice bed...
cool, thanks
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 11-25-2009, 04:36 PM   #35
420am
420am's Avatar
subscribed/inspired
1972 Long Bed Cheyenne
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282
Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday)
420am is offline   Reply With Quote
Old 11-25-2009, 10:00 PM   #36
squirel
squirel's Avatar
Dan in Pasadena: yes the exterior varathane diamond coat it is a waterborne paint here is a picture of it as I can not find it on there website
My build page
