Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-24-2009, 08:39 PM   #751
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: "Slowly but Surely" Big J's build thread...
Installed the clutch/brake assembly, shift and trans levers, some firewall rubber stuff, kick panel vent doors, and the cup holder. Still have some adjusting to do on the cup holder but its neat. Started to put the tailgate together but I guess I've lost or forgot to buy those little clip things. So its a no go on that until I get some of those little clips.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 11-24-2009, 08:45 PM   #752
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Looking good J...you're almost there!
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 11-25-2009, 02:21 AM   #753
ClifBlazer
ClifBlazer's Avatar
you'l have to show some close ups on that cup holder
ClifBlazer is offline   Reply With Quote
Old 11-25-2009, 09:22 AM   #754
lks dcvn
lks dcvn's Avatar
Looks AWESOME!
Nice work for sure - it is threads/posts like this that make you want to go directly out the shed/garage/yard and look at what it out there and say - I can really do this stuff if I put my mind to it.
Thx for the pix! Keep up the good work and looking forward to future updates...
lks dcvn is offline   Reply With Quote
Old 11-25-2009, 01:12 PM   #755
Big J
Big J's Avatar
Originally Posted by lks dcvn View Post
Looks AWESOME!
Anyone can do this. I started out doors, with basic wrenching knowledge. Through this build I've learned the rest, welding, painting, bodywork, SANDING, lol, etc. This board is a great help and influence. Anytime you have a question someone has the answer. I've got two locals too that have always been a big help, jamie72 and Huck.
BAZINGA!
My Build
Old 11-25-2009, 10:21 PM   #756
Big J
Big J's Avatar
Had to take it back out and do some tinkering. It works kinda like a door on a entertainment center, to close push in and it locks in place, push again and it pops out. I didn't like that because it held the front out 3/8's of an inch from the dash. Didn't look right. I pulled it apart, took the spring and lock out. Now it goes against the rubber bumpers like it should. It has some good resistance so it won't be sliding in and out by itself. I took several pics of it for those interested in how it mounts up and what not.
Got a few other things bolted up in the short goofing time I had. Tailgate hardware that goes on the back of the tub and wiper motor.
Heres the spring and plastic piece I pulled out.
BAZINGA!
My Build
Old 11-29-2009, 10:45 AM   #757
Bentblazer
Bentblazer's Avatar
Use the gun to put a hole in the firewall?
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 11-29-2009, 12:40 PM   #758
jaros44sr
jaros44sr's Avatar
Hey J, nice work! Guess I didn't read back far enuff to find out where you got the cup holder. Any help? I like it.
Keep your chin up!!!
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-29-2009, 05:22 PM   #759
Big J
Big J's Avatar
Thats not a gun, its one of those new +P pop rivet guns. It really gets'em in there.
I picked that up in the before time in the long long ago. It seems they've went up quite a bit from when I bought mine. Maybe one of the vendors here can get it to ya cheaper.
http://southernkyclassics.com/product.php?skcid=1000280
BAZINGA!
My Build
Old 11-30-2009, 12:26 AM   #760
Big J
Big J's Avatar
It seems like I've been spending more time looking for parts then installing them. It took me an hour to find part of the ignition switch assembly, 20 minutes getting the old cylinder out, and 60 seconds to install it. It took 2 days for me to find my dash pad. Talk about stressin', lol. I knew I kept the original, it was in great shape. Tore through 2 storage buildings and 2 garages 3 times each. Yep, 3rd times a charm. I finally found it tonight in the box with my rear bumper. We always seem to put stuff up so we won't loose it don't we, lol. I used Duplicolor vinyl paint on the dash pad. Cleaned it, scuffed it with 400 and cleaned it again. Hopefully the paint holds up. Got the e-brake installed along with the ignition assembly and cig. lighter.
BAZINGA!
My Build
Old 11-30-2009, 11:29 PM   #761
Big J
Big J's Avatar
Got the front fender seal set put together today. Oh what fun. First I tried to epoxy it together. That was a huge waste of time. It just wouldn't stick. The kit came with some huge staples but I don't have the tool for those (thats why the epoxy). So I ended up getting out the hammer, needle nose pliers and a drill. Got the staples in and finally got it done.
BAZINGA!
My Build
Old 12-01-2009, 08:56 AM   #762
lks dcvn
lks dcvn's Avatar
I just pulled the psgr side fender seals over the weekend - I was wondering how you would repair and replace them.
Old 12-01-2009, 10:04 AM   #763
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
BigJ...
Those dust seals are a B---h arent they? I ended up doing the same thing. Also, mine have been hanging from the top holes for a couple months now. The bottom holes arent there anymore because that area was replaced
If you have a pic of that area as its supposed to be drilled... it would be appreciated.
Tom Vogel is offline   Reply With Quote
Old 12-01-2009, 10:24 AM   #764
lks dcvn
lks dcvn's Avatar
If you want I can get some shots when I get home - they are still off the truck and the sheet metal is pretty clean where they bolt in...
Shoot me a PM to remind me - if you want a shot or two.
Old 12-01-2009, 07:05 PM   #765
lks dcvn
lks dcvn's Avatar
Pix of the A pillar and cowl where the bolts go for the inner fender seals.
If you need more or need measurements - just say the word and I can get more when I get a chance.
There is only a few bolts that actually hold the metal bracket thing to the Blazer body - the rest bolt the actual seal itself to the body.
Old 12-01-2009, 09:02 PM   #766
Big J
Big J's Avatar
Thanks for takin' the time to post the pics. ^^^^^
Got the brake booster bolted up. Its huge compared to the stock one. I'm either going to lengthen the brace or just make a spacer for it and use a long bolt. I think the spacer will be the easiest route. Got the biggest part of the wiring harness gone over, taped up and laid out. Got the gas pedal figured out. The 70 tub used a different pedal assembly then the 72 and thats what I want to go with. Its workin' out though.
In other news I've got two new dogs. The first one a Chihuahua (Prissy) was given to us by my grandmaw, she had to move and could only take one dog with her. The second is a Puggle (Belle), half Beagle half Pug. My brother and sister inlaw dropped by the day before Thanksgiving and said, "We've bought you a early Christmas present!". Prissy is a little over a year and a nutjob. Belle is 14 weeks and house training great. I lost my last pup of 14 years about 6 months ago, its nice to have them back in the house. Gotta love dogs!
BAZINGA!
My Build
Old 12-02-2009, 06:43 AM   #767
vtblazer
vtblazer's Avatar
Great pic!
...blazer's looking good too.
vtblazer is offline   Reply With Quote
Old 12-04-2009, 12:48 AM   #768
Big J
Big J's Avatar
Now it looks like a Blazer. Got the doors, fenders, tailgate, hood hinges, dash pad, some more wiring, made a neat bracket for the the throttle to go into the firewall, redid the fuel filler neck(wrong angle on it) and probably some other stuff I'm forgetting. A BIG THANKS to jamie72 for coming out to help toss on the sheetmetal. Hope he makes it back soon to finish it, lol.
Heres the hole for the throttle cable. Big hole under the little hole. Bolt goes through the little hole into the bracket.
Heres the bracket and the throttle cable.
BAZINGA!
My Build
Old 12-04-2009, 01:49 AM   #769
jaros44sr
jaros44sr's Avatar
Nice work guys, I like that third pic. Doesn't look like ya did that much sanding
SAFETY FIRST
AS usual, off topic
Jim
Old 12-04-2009, 07:01 AM   #770
Chevyman63
Chevyman63's Avatar
Awesome J....it does look like a Blazer again. Your getting close!
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 12-04-2009, 07:26 AM   #771
vtblazer
vtblazer's Avatar
Lookin' like you'll have a complete ride before the rest of us by a long shot.
Good to have someone to help too.
Old 12-04-2009, 10:16 AM   #772
Yukon Jack
Yukon Jack's Avatar
Looks great in yellow!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-04-2009, 10:15 PM   #773
Big J
Big J's Avatar
I wish I was done sanding. I'm gonna wet sand the whole thing with 400 and reshoot the outside. Hopefully soon.
I know, I wanna work on it 24/7 to get it done, lol.
It wouldn't be where its at if it wasn't for Jamie72 and you guys on this board. Thanks to all!
Can't wait to get it outside to see how bright it really is.
BAZINGA!
My Build
Old 12-05-2009, 09:48 AM   #774
5150
C10 Club Tennessee
5150's Avatar
are you bringing that thing to truck show next year?????
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 12-05-2009, 11:08 AM   #775
Big J
Big J's Avatar
Man I want to. All depends on funds and a few other crazy things. Should have some road time on it before then, probably have some bugs to work out.
BAZINGA!
My Build
