Just replaced passenger front flexible brake hose and...
Need a little advice (79 2wd disc brakes). The line busted and replaced without an issue. Do I need to bleed the entire system or just the front brakes?
Thanks Brad |
Re: Just replaced passenger front flexible brake hose and...
you should only have to do the fronts.. but if i were you id just go ahead and bleed em all the way around to make sure u got all the air out
"I'll keep my guns, money, and freedom. You can keep the "change" |
![]() Join Date: Jul 2009
You can typically just bleed the affected "end" of the truck if it has a 2 reservoir style master cylinder which your year truck should have.
