11-25-2009, 03:29 PM | #1 |
LS Engine guys
What are you all using to mount the AC compressor? I have a sanden compressor from Old Air Products.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-25-2009, 05:06 PM | #2 |
Re: LS Engine guys
I just used all the factory stuff (factory compressor). Mine is the truck accessories, it is a tight fit between the frame rails. I have to install it after the engine is in.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
11-25-2009, 05:09 PM | #3 |
Re: LS Engine guys
I hear, but don't really know, that you will have to notch the frame rather big, this is what I want to avoid. There is an aftermarket bracket that will work, but it is like $200.00+, which again, I want to avoid forking over a bunch.
11-25-2009, 05:24 PM | #4 |
Re: LS Engine guys
I'm using an F-body compressor on a corvette bracket. I notched the frame just a little for line clearance. I haven't gotten it hooked up yet. I'll probably end up with a custom block on the back of the compressor.
11-25-2009, 05:27 PM | #5 |
Re: LS Engine guys
Are you using fbody pulleys and stuff? or are they from a truck? I would like to see your idea. If ya dont mind that is.
11-26-2009, 01:36 AM | #6 |
Re: LS Engine guys
i use the factory truck mount with the factory truck compressor with performanceonline.com engine stands, and did no frame notching at all... fits like a glove.
11-26-2009, 02:40 AM | #7 |
Re: LS Engine guys
I have a 5.3L in my 72 Tahoe and with a DropMember the motor is raised up 2" and my stock set up fits great! No notching and the comp is on the motor when dropped in place.
Kevin LFD Inc. |
