Old 11-26-2009, 01:39 AM   #1
mongoose
mongoose's Avatar
TBI > Carb.
I'm picking up a Blazer to replace my LWB, and the blazer has tbi.
i'm wondering if i can just run a normal regulator, since the stock pump puts out 15? ish psi, or do i need to run it with the return line? what is the best thing to do, for those who have done the swap?
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 11-26-2009, 01:49 AM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: TBI > Carb.
Are you switching from TBI to carb? If so, why? The TBI pump is low pressure ~13-15 psi. You will need a regulator to keep it @ 7psi for a carb. application. Good luck.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 11-26-2009, 02:28 AM   #3
mongoose
mongoose's Avatar
Re: TBI > Carb.
i have a vortec headed 350 i want to put into it, with a carb already.. and i don't want get a new intake for a the tbi to fit.. seems easier to me.
let me refrase my question.. i'm wondering if the pump will burn up if i don't have the return line hooked up.. or do i need to run a bypass style reg.?
Old 11-26-2009, 11:30 AM   #4
STOCKISH
STOCKISH's Avatar
Re: TBI > Carb.
They sell an adapter to put a TBI on a carbed manifold for pretty cheap if you are interested. You wont need a return line if you use a regulator set for 7 psi.
--Josh
Old 11-26-2009, 12:59 PM   #5
SSC's76
No No
SSC's76's Avatar
Re: TBI > Carb.
This is a common swap. You want a return style regulator its not needed but but will let the electric pump live alot longer. $60 now for the regulator or $80.00 for a new pump and $60.00 more for the regualtor you should have used in the first place. 12803BP is the holley number for the correct regulator. They sell cheap brand units just make sure there similiar in specs.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
