![]() Join Date: Jul 2009
Unidentified 200 4R
I have found 2 2004R transmissions but nothing matches up to tell me what model or year they are! Can anyone help?
Thanks Last edited by mikey531; 11-29-2009 at 06:16 AM. |
Re: Unidentified 200R4
Anyone? I have been looking at every 2004R site I can find and nothing matches. What am I doing wrong?
200r4, sounds identified to me.
does it have a bop or chevy bell? whats the out put spline? |
It has the universal bell housing. I wanted to find out what year and car it came out of. That is where I am having the problem.
Thanks. |
KJ '86 to '90
its all about the +6 inches
![]() Last edited by Longhorn Man; 11-29-2009 at 11:31 PM. |
optomistic ah-so
I'm guessing what you are really trying to find out is if it came from one of the models with the higher strength ratings, Like the Monte SS, Buick GNX, Olds 442.
Buick units are identified by the BQ or BRF transmission codes. Monte Carlos used the CZF code. The Hurst Olds/4-4-2 units had a KZF or an OZ code. Any other code (KJF, TKM) was a standard build. Hemmings also lists the following decoding info: 1st digit: month of production (A through M, skipping the letter "I") 2nd-3rd: production day of the month 4th: shift transmission was produced (1st-3rd shift) 5th: assembly plant (T: Three Rivers, MI; J: Windsor, Canada; W: Warren, MI) 6th-7th: decade and year 8th-9th: or 8th-10th: transmission ID code 10th-13th: or 11th-14th: transmission serial number While that info is oversimplified and the second tranny (yellow tag) seems to have some conflicting info (like NO production shift, which could result from OT weekend, or labor trouble) it still seems to be from a 1982 Oldsmobile. The first one is so far off I think it would be a good idea to look at the pan and make sure it's really a 200-4R
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. ![]() |
425hp409
![]() Join Date: Oct 2008
Re: Unidentified 200 4R
The month and year of the trans case is in a small circle on the left side of the case above the shift lever. Like 3 86
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
