Old 11-28-2009, 11:28 PM   #1
SS68
SS68's Avatar
Need help with steering gearbox
Last week my gear box started leaking. so i looked around and bought a rebuilt one from the local napa for around $140 with an $80 core. Now onto the problem, I put it in today but now the truck feels like it has no power steering at all i open the pressure line going into the gearbox and it shoots out fluid. i open the return line and also fluid shoots out. what am i forgetting to do? i lifted up the front end and turn the wheel both sides check fluid level and its full. but once i put it back on the ground its hard to turn. Anybody have any suggestions?
SS68 is offline   Reply With Quote
Old 11-29-2009, 09:05 AM   #2
JimKshortstep4x4
Re: Need help with steering gearbox
If your other box worked and now the new one doesn't after bleeding then you may have a bad box.
Is the new box noisy? Sometimes it is hard to get all of the air out.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-29-2009, 09:34 AM   #3
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
I gotta believe a bad box in this case
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 11-29-2009, 10:49 AM   #4
SS68
SS68's Avatar
how do i know if the power steering pump is circulating the fluid? is it like the radiator where you can see the fluid circulating?
Old 11-29-2009, 11:03 AM   #5
mbgmike
You have air in it.
You reservoir should not be full after install and turning the wheels
Did you bleed it correctly?
I would replace all hoses and fluid also when doing this. Probably needs it anyway unless you know the last time it was done.
Jack the truck up with the tires off the ground.
turn wheel all the way to left fill the reservoir to full cold. don't start truck. T
Turn the fwheel back and forth until the level drops. If it does not drop
nothing is happening. and air is in the system. Untill its out its not going to work
Turn wheel slow NOT fast to allow air out
do this until the level drops and does not drop anymore. Now pull the coil wire. crank the engine until you see if the level drops if it does there is still air. check for foaming too. If so go have a beer and wait 15 minute or whatever come back and do it again till there is none.
If it still does not work its probably bad. or the piston is stuck inside.
mbgmike is offline   Reply With Quote
Old 11-29-2009, 11:44 AM   #6
Sammy
I had a similar problem after replacement of the gear box. That may be worth trying. remove the pressure line from the pump. Then remove the fitting. There is a very small screen there. Clean that screen. It doesn't take much too interfer with proper pressure. Then rebleed the system as others have suggested. This may solve your apparent lack of pressure in your gearbox and is easier than replacement of the gearbox. Good Luck.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 11-29-2009, 12:01 PM   #7
SS68
SS68's Avatar
your saying take the pressure line out of the power steering pump not the gearbox? and clean the screen correct? both hoses have been replaced about 4 months ago when i replaced the power steering pump. and as far as the fluid it the reservoir was completely dry when i replaced the leaking gearbox and is there a way to get the piston unstuck?
Old 11-29-2009, 02:40 PM   #8
SS68
SS68's Avatar
ok problem fixed now. thanks to everyones reply. but the old man took one look and told me the power steering belt wasn't tight enough. i had a feeling i overlooked something. when i was turning the wheel you could see the puley of the powersteering pump just stop i tightened up and now its smooth. in case some one else runs into this problem.
