Old 11-29-2009, 08:07 AM   #1
mblackburnjr
collector of vintage rust
mblackburnjr's Avatar
trailer brake control
I am hooking up on 2001 Silverado. Cant find where to hook brake wire into electric panel under hood. anyone?
mblackburnjr is offline   Reply With Quote
Old 11-29-2009, 11:35 AM   #2
Gray Ghost
Gray Ghost's Avatar
Re: trailer btake control
There should be a separate harness for the controller. I have one that sits in my workshop waiting for the day I get trailer brakes on my trailer. Not sure where it plugs in though.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 11-29-2009, 12:52 PM   #3
mblackburnjr
truck is factory wired to electrical panel under hood. I cant find where to plug in the blue brake wire. truck is 1500 series extended cab.
Old 11-29-2009, 02:51 PM   #4
Gray Ghost
Gray Ghost's Avatar
Sounds like your truck is different from mine...hope you find out.
Kelly
Old 11-30-2009, 03:03 PM   #5
mblackburnjr
Came from factory with tow package. Someone has removed trailer brake control.
Old 11-30-2009, 08:32 PM   #6
Gray Ghost
Gray Ghost's Avatar
OK....There is an available harness that does it all for you. It plugs into the main harness under the dash somewhere and the other end goes to your brake controller. You shouldn't have to wire anything yourself. I will go out and get the PN off the harness for you....but just for grins I gotta ask, have you looked up under the dash yet to see if the harness is there?
Kelly
Old 12-01-2009, 01:54 AM   #7
SkylineNXS
SkylineNXS's Avatar
I have a 00 sierra extended, so it may be different, but right behind the parking brake pedal there is a "black box" cover, if u remove that, i do believe that is where u are supposed to plug in, at least my aftermarket controller wires to this location...
Brad
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 12-01-2009, 07:39 AM   #8
mblackburnjr
The wire is under hood at electrical center.
Old 12-01-2009, 04:11 PM   #9
JohnC
JohnC's Avatar
Brad
My 03 GMC, and 02 Chevy have the plugs both in this same spot.
JohnC is offline   Reply With Quote
Old 12-02-2009, 02:31 AM   #10
SkylineNXS
SkylineNXS's Avatar
I hope this helps out, it is for my 00 sierra, but hopefully urs should be similar...
send me a pm if u need a higher res pic, i have good eyes and can read this, haha....
Brad
Old 12-02-2009, 02:47 PM   #11
mblackburnjr
Re: trailer brake control
The wire is under the hood at electrical center. If you have a pic of that would help.
Old 12-02-2009, 08:35 PM   #12
1978steven
1978steven's Avatar
+1
Brad
+1
NBS GM's from 1999-2007 Classic with the tow package came with the harness to wire up an aftermarket brake controller. Splice the wires from your controller to the GM harness and plug into the black box behind your emergency brake pedal. Then put the fuse that was wrapped up with the harness in the under hood fuse box, and your done.
Sounds like you need the GM harness, it makes it very easy....
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
Old 12-03-2009, 08:26 AM   #13
mblackburnjr
Blue wire is already at elect. center under hood. I just need to find where to plug it in.
Old 12-03-2009, 02:15 PM   #14
Shon
is the blue wire for ground or constant 12v?
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 12-03-2009, 03:25 PM   #15
mblackburnjr
It runs back to trailer plug. It actually is what applies the trailer brakes.
Old 12-03-2009, 03:29 PM   #16
Shon
Does this help??
http://www.etrailer.com/faq-wiring.aspx
The blue wire runs from the controller back to plug where the trailer plug hooks to and then it sends the signal (ground I think) to the trailer brakes.
Old 12-03-2009, 03:31 PM   #17
Shon
Also here
http://www.chuckschevytruckpages.com/trailerlights.html
blue is ground.
Old 12-03-2009, 06:34 PM   #18
1978steven
1978steven's Avatar
This blue wire from the rear connector to the engine compartment?
2004 Tahoe LT
1971 Chevy C10
Old 12-04-2009, 03:43 PM   #19
mblackburnjr
Blue wire comes from light plug at rear of truck.Goes to electrical center under hood. Wiring from controller plugs in at park brake. Runs out to electrical center under hood. What i am asking is where do the blue wires connect? The blue wire has a plug but I cant see where it plugs into the elec center. This is the one coming from rear.
