Old 11-29-2009, 02:20 PM   #1
Thealien
Thealien's Avatar
72 Jimmy gear ratio
Are 4.10 gears common or uncommon in 4WD blazers and Jimmys?
I thought my Jimmy was sceaming on the highway.
Old 11-29-2009, 08:19 PM   #2
Re: 72 Jimmy gear ratio
Somewhat common,but optional-only.Tell us more like tire size how fast you were going,and/or what rpm if you have a tach.
Old 11-30-2009, 07:31 PM   #3
Thealien
Thealien's Avatar
I am running 31 inch tires and do have a Tach dash. Going about 65 (most likely faster because of the bigger tires) and I swear it was reading about 32-3300 RPM. I know our Tachs are not the most acurate but I always assumed I had 3.73s. I did the spin the driveshaft just over 4 turns for 1 tire revolution so I assume 4.10s. I did the front axle also with the same results.
I need the info for a PCM tune for a future project (soon).
Old 11-30-2009, 11:57 PM   #4
70 beast
Certified Hobbiest
70 beast's Avatar
i spun my driveshaft 2 full turns for one tire rotation with a 38" tire and pulled to cover to make sure but it had 4.56s
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
