Old 11-29-2009, 02:18 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Where do I wire electric choke up to in the fusebox?
Gonna wire up my electric choke today, where do I wire it to in my fusebox? And will need some help 'tuning' the choke (where do I set it at?)
thanks
John
1999 Toyota Tacoma 4x4
Old 11-29-2009, 02:43 PM   #2
oldblue1968chevy
Re: Where do I wire electric choke up to in the fusebox?
would It go to ign. unfused?
John
Old 11-29-2009, 03:05 PM   #3
GASWAGON
AMERICAN IRON ADDICT
You can but you really should have it go to ign. fused, or install a inline fuse to be safe. Also use a volt meter and make sure you have 12 volts at the panel or the choke won't work properly. If the carb is new try the factory setting first.
GASWAGON is offline   Reply With Quote
Old 11-29-2009, 03:18 PM   #4
tim21391
tim21391's Avatar
theres a spot on the fuse box that isnt use maybe there?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 11-29-2009, 03:49 PM   #5
oldblue1968chevy
Well...Im not really sure but I'll look...Anybody know any spots on the fusebox I can wire this to?
Ive got it wired with no fuse, and the choke doesnt open close, but its also 55* outside. Is this correct? And what should my choke be set at?
John
Old 11-29-2009, 04:52 PM   #6
stevewhitmore
stevewhitmore's Avatar
I wired mine to a fused terminal that is only powered when the ignition is on with a full 12 volts, that is what the Edelbrock manual said to do
stevewhitmore is offline   Reply With Quote
Old 11-29-2009, 05:07 PM   #7
haysonj
haysonj's Avatar
If you don't have AC you can put it on the spade that is on the bottom left side of the fuse panel. This spade is fused and hot when the key is on. As for adjusting take the breather off make sure the engine is cold and turn the choke until the butterfly just barely closes. Turn the key on and the butterfly should open after a few seconds
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 11-29-2009, 05:16 PM   #8
oldblue1968chevy
haysonj
THANKS going out there now! Well, going back out
John
Old 11-29-2009, 05:20 PM   #9
oldblue1968chevy
I see an AC fuse... but no AC spade plug in?
(im staying out of the rain as long as I can )
John
Old 11-29-2009, 05:39 PM   #10
haysonj
haysonj's Avatar
The one that says CIG Is the one I was refering to. You should check it to see if its hot with the key on and not hot with the key off.
Old 11-29-2009, 05:44 PM   #11
oldblue1968chevy
Yeah..thats what my cig. lighter is wired to.....
whata bout the one next to the fuel gauge?
John
Old 11-29-2009, 05:52 PM   #12
haysonj
haysonj's Avatar
Any off them will work if they are hot with the key on. Check to see if your lighter works with the key off If not you can splice into that wire
