#826 |
HOW long until spring??
![]() Join Date: Mar 2009
Re: The 283 Rebuild Begins
http://67-72chevytrucks.com/vboard/s...d.php?t=324250
63-64 bowties had this link in january 09-- '63 turn signals
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#827 |
Registerd User
Flashing break lights when they are not applied might be your boo switch being out of adjustment or busted. Please explain on t/s sticking on when brakes applied? Like hazzards or just one side? Just the back?
Trucks lookin good Mac. |
#828 |
283 Drama Queen
![]() Join Date: Dec 2004
Thanks Jason, the rear stop/turn lights both flash, as soon as the ignition switch is turned on - even without engine not running. Put the brakes on - they stop flashing and you can't hear the "clicker" can going off under the dash.
Flashing lights only effect the back - not the front of the truck. Driving, put a turn signal on, right or left and they operate fine, front and back - until you apply the brakes - then whichever side it's set to - the light sticks on and won't flash until you take your foot off the brake. Understand - the tranny shop did the final hook-up on the wire loom (click in unit) coming down out of the steering column. Also understand I FAILED Basic Electrical shop in high school, TWICE! But the teacher was a real P*%#k. Mac. ![]()
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
#829 |
Rods
![]() Join Date: Nov 2002
Could be a few things... I know its been said. But start at your light grounds... They will feed back if they is not a good ground.
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
#830 |
http://www.americanstreetmasters.com/Wiring_101_16.jpg
this is a helpful site .. the colors stay consistent through the years. Do you have the hazard 4-way flasher? Power starts at the fuse ,then to signal flasher then goes to the brake switch on the orange wire and leaves the brake switch on the white wire which goes to the connector and up the column to the turn signal switch. the 4 signal lights (front/rear turn /brake) all leave the turn signal switch on 4 different colored wires. your flasher only flashes when it has a load to pass power to. It sounds to me like your turn signal switch or column wiring has been damaged. Or mis-connected good luck-- Bubba
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 11-17-2009 at 09:44 PM. |
#831 |
283 Drama Queen
![]() On the emergency flasher issue - my truck didn't come with them and I can hear the regular canister firing off, which makes both stop lights illuminate. Mac. ![]()
#832 |
Glad you found it. I put a newer Gm tilt column in my 64 and added the 4- way hazard lights. It only took a extra flasher and one wire using the newer turn signal switch which was in the column.
#833 |
283 Drama Queen
Truck's Puking Oil.
Not bad - but on the brand new driveway - it's quite noticeable. A spot about 2 inches wide and 4 inches long. Noticed it when the kid put the truck in the garage yesterday. Haven't checked out the exact location, but its not tranny fluid or anything else and I'm taking it easy for the holiday - so I'll worry about it when I get the rig back from the electrical repair guy two Saturdays from now. Typical. ![]() More-than-likely the small I/D tubes I ran from the PCV valve from the original tube back by the distributor, up to the carburetor, aren't producing enough flow/suction to relieve the crank case fumes. Based on the fact the spot is right in the center of where the truck was setting - it's probably a rear seal. Oh joy. ![]()
#834 |
there was a change in the wiring to the lights in 65 or 66 in regards to the frt parking lights remaing on with the tail lights. prior years the park lights were not on with the taillight when running. perhaps when they fix your wiring there may have been some confusion.
just throwing that in for thought Mac ron |
#835 |
283 Drama Queen
Thanks Ron - every little bit helps.
#836 |
Rods
Mine was a pan gasket on the front.. Hit the crossmemeber then made a spot right under the engine. I thought rear too.
#837 | |
283 Drama Queen
#838 |
283 Drama Queen
![]() Now it's not that I'm a Drama Queen or anything (yeah, right), but I think I found the source of the leak: Fitting off the back of the block that feeds the oil pressure gauge. The last guys that worked on my rig - putting the gears in the differential, new drive-shafts, brakes etc - also did some wire clean-up in the engine compartment. They put one of those flexible plastic wire sheaths over the bundle on the driver's side, but didn't secure it properly. I got a few minutes yesterday and fired the truck up to see if I could eyeball the source of the dripping and discovered, as I pulled the throttle rod back, this loom was riding up and down on the rod - pulling on the plastic oil line that was bundled in with the various wires. Every time you'd step on the gas it would give this line a good yank. So I took a Velcro wire strap and tacked the whole mess to the firewall and re-tightened the tube's fitting. I'll go back and clean everything up, but there was a fair puddle of oil near this fitting at the top of the motor - near the distributor. Oh the Humanity! ![]() Dropped the truck off at the electrical repair guy's shop before work this morning - so we'll see if he can get my charging system working. A 64' Impala with a monster, late-model Corvette motor was there for a wiring restoration, so I may have found a decent vendor. Mac. ![]()
#839 |
Shloooooong bed member #2
![]() Hope it solves your problem..
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
#840 |
Registerd User
Glad you found your leak Mac.
#841 |
SSN 706
#842 |
He found his leak too. That's recycling at it's best.
http://67-72chevytrucks.com/vboard/s...54#post3194654 Last edited by shrunken66stroker; 11-30-2009 at 12:05 PM. |
#843 |
This is why I am glad I have the ability (time and knowlege wise) of doing these projects myself.
I get so dissappointed when you pay someone good money to do a job. Then when you get it back you find problems. It got to the point that I just started doing everything myself. So far I have tackled everything but rebuilding an automatic transmission and setting up a rear axle. I was going to add radiator repair, but not even the radiator shops repair much anymore, just R and R. Last edited by justcuz; 11-30-2009 at 12:53 PM. |
#844 | |
283 Drama Queen
Thanks David – I’m just glad I didn’t have to change the smog plumbing.
Me too, Jason. Because of the leak’s position and me being such a gigantic mechanical whoosie, ready to throw myself down on the garage floor and cry, I was sure I had a D.O.A. rear seal. Guess I lucked out this time. OMG. You didn’t actually post that?! ![]() It has been a while since we’ve had one that funny! Unbelievable. ![]() Quote:
![]() And because I’ve got a back-up vehicle to get me to work, you’d think I’d just block out the time and learn to do everything myself. The guy I dropped the truck off with is $98 an hour – with an hour minimum. In today’s economy – there are zero excuses not to at least try to do this stuff yourself and I’ll be looking at about four grand I didn’t really have to spend by the time this truck's finally done. Impatience and listening to others (that clearly know little if anything about these vehicles) tell you how you should spend your dough is sometimes very silly. $4,000 buys a Hell of a paint job.
#845 |
Between Autozones online program, which costs nothing to register, and sevice and shop manuals you can pretty much diagnose and repair anything.
You can buy a ton of shop manuals one ebay for a couple hundred dollars. These older trucks are pretty easy, wiring schematics are pretty simple and diagnosing stuff is simple since it is so easy to see everything. The newer fuel injection stuff is what is causing me some heartburn now. |
#846 | |
283 Drama Queen
#847 |
283 Drama Queen
Called the electrical repair guy a while ago - looks like I'm getting The Tan back tonight. Everything is supposedly corrected and a "tumbleweed of wires" and connectors pulled from under the dash. It's funny - out of the half-a-dozen old trucks I've ever owned, seems that "extra wire" has always been part of the purchase price.
Now obviously - I'm no electrician, but why do people do that? (Now I can borrow my buddy's car trailer and haul my truck back to Alan's shop.) Mac. ![]()
#848 |
Congrats Mac.....
Hey swing by and grab my truck on your way to Alan's ![]()
#849 |
283 Drama Queen
#850 |
Registerd User
Thats great Mac. So is it charging now?
Ok is on the way. ![]() |
