Old 04-20-2003, 09:40 PM   #1
Green72GMC
Green72GMC's Avatar
Wiring/Gauge Problems/Questions
I have a 305 out of an 86 caprice in my truck. The previous owner had no gauges hooked up except the fuel on the old motor (yea no speedo hooked up either, I got that hooked up now). I only have a small idea of where to hook them up. There is a prong on the front of the motor on the right side. Then there is one with two prongs on the right side toward the back of the motor. The problem is I only Have four wires. Here are the colors: brown and white, dark blue, black and a large pink one. I would like to atleast get my temp gauge working. I have looked at 2 different wiring diagrams and I dont understand them. Which wires do I hook up where?
1972 GMC SWB, 305 powered
1980 diesel VW pickup, Needs a Heart Transplant
1997 Toyota Taco
The Second Amendment is in place incase they ignore the
others.
Green72GMC is offline   Reply With Quote
Old 04-20-2003, 10:09 PM   #2
Class of 69
Class of 69's Avatar
My book is for a 69...shows dark blue to oil pressure, dark green to water temp. The only thing I see with pink, and black wires, is a trans downshift switch...RPO M-49.. Don't see a brown and white wire in here. They could well have changed colors by 72.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 04-20-2003, 10:16 PM   #3
Green72GMC
Green72GMC's Avatar
Thanks man, im gonna go try it, I just gotta figure out what the pink one is. It carries electricity to something, I can touch it to the frame and sparks fly.
1997 Toyota Taco
others.
Old 04-20-2003, 10:24 PM   #4
Class of 69
Sounds like the main power wire to the alt, if you can weld with it!! They start out red, but can fade to pink with time.
