11-30-2009, 07:10 PM | #1 |
Grandpa in the rustmobile...
I have ALOT of surface rust in the inside of my cab..
Ive gota lot of surface rust on the inside of my cab (orig. paint) tried rubbing compound but seems to take more paint off than I want...is there a better way around this? thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
12-01-2009, 09:21 AM | #2 |
Tot Roddin'
Re: I have ALOT of surface rust in the inside of my cab..
oldblue... before I attempt to offer a solution, do you have any shots of what we're dealing? I'd hate to give you some things to try and then end up making it worse.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-01-2009, 03:28 PM | #3 |
ok will try to get picture tonite..it is pretty rusty...
12-01-2009, 09:06 PM | #4 |
sand and repaint?
12-01-2009, 10:35 PM | #5 |
well yeah, thats also an option lol...
03-19-2010, 08:47 PM | #6 |
I am a Referee of life.
No sanding was needed when I did mine.I did a spray bomb job on my interior about7-8 years ago.I started by sanding and priming.Did it to some areas and since I was doing a section at a time,it was taking forever.So I tried some steel wool.There were some areas that had surface rust that still needed to be sanded/primed but most of it was just steel wooled and primed then steel wooled again(to smooth the surface and provide"tooth".I then painted and actually the areas that were preped with steel wool seem to still look a bit better.I washed the metal with a soft towel(lint free) and just plain water after steel wool to make sure I wouldn't trap any steel/rust wool particles in the paint.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-20-2010, 08:32 AM | #7 |
where exactly in the cab? roof? floor? back? dash?
03-20-2010, 09:41 AM | #8 |
mostly roof some dash but it would all get painted inside doors roof around glass dash etc
