Old 12-01-2009, 10:51 AM   #1
68_Step
Question Brake Tools
I am getting ready to dive in to a brake job on my 1978 Chevy. It is a 4x4, 1 ton, dual wheels. I am planning to start on the rear drum brakes, inspecting and replacing (or turning) as required.
Are there any special tools that I will need? It has been long time since I have done anything to drum brakes.
68_Step is offline   Reply With Quote
Old 12-01-2009, 11:29 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Brake Tools
I have done a lot of work on drum brakes (since the 50's) but always on 1/2 tons. I don't remember using this handy brake tool below but very few times (mostly, because I can't seem to find the doggone tools when I need them).
I use a pair of vise grips, duck bill pliars and two screwdrivers. One screw driver to move the star adjuster and the other to push the auto adjusting lever out of the way while loosening the drums. The vise grips for the springs and the duckbill for the retainers. Since you have a 1 ton, I think you may want to use the hand tool for the springs.
68gmsee is offline   Reply With Quote
Old 12-01-2009, 11:38 AM   #3
Sinister
Between Trucks...
Sinister's Avatar
Re: Brake Tools
I hate doing drum brakes, but the tool 68gmsee posted makes it a lot easier. Should be available at most parts places.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-01-2009, 11:52 AM   #4
matthew.mcmullin
Re: Brake Tools
I only do one side at a time. Then I can always look at the other when I mess it up or get temporarily confused
matthew.mcmullin is offline   Reply With Quote
Old 12-01-2009, 12:04 PM   #5
Rack Man
Re: Brake Tools
Here, check out this awesome link....Just in case you need a little assistance in the parts or sequence!
http://www.pbase.com/nufsed/drumbrake
RM
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 12-01-2009, 01:49 PM   #6
mrein3
mrein3's Avatar
Re: Brake Tools
RM
This is a good link - if you're working on a 1/2 ton.
The brakes on your 1-ton are similar but the drums are not. You'll need a spanner wrench just to get into them if I remember correctly. It has been a long time since I worked on a 3/4-ton or 1-ton rear.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-01-2009, 03:14 PM   #7
68_Step
Re: Brake Tools
68gmsee / Sinister: I saw those at my local auto parts store yesterday - will pick them up.
RackMan: Now that is what I call step by step instructions! Since I have a 1-ton, if mine look different I will grab the camera.
matthew.mcmullin: Since I never get confused I will take apart both sides
mrein3: Spanner wrench? I do not have one of them - is this to help pull the drum itself off?
Thanks everybody!
Old 12-01-2009, 10:15 PM   #8
mrein3
mrein3's Avatar
Re: Brake Tools
Originally Posted by 68_Step View Post
snip...
Thanks everybody!
Yes.
Once the drum is off it is a similar only much larger setup as 1/2 ton brake shoes.
'72 Malibu hard top
Center City, MN
