12-01-2009, 03:59 PM | #1 |
help with wiring
I recently purchased a rebel wiring harness to rewire my truck and I literally have no idea what I am doing. Ive never wired anything up before. Can anyone suggest a good starting point or a thread where someone has posted a walkthrough. I know it should be pretty straight forward but I dont want to screw anything up.
Its a '65 LB, if that info is needed. |
12-01-2009, 04:06 PM | #2 |
Re: help with wiring
The way I have always done anything wiring like is divide it up into small parts, for instance, remove the original fuse block and install the new one, then take the nearest clump of wiring and remove it, then replace it with new and so on. You can have a check off sheet to make sure everything is covered. Also dont they have a tech support line for assistance if you need?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 12-01-2009 at 04:06 PM. |
12-01-2009, 04:30 PM | #3 | |
Good luck on your project
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) |
12-01-2009, 05:16 PM | #4 |
hey thanks for the responses. I ended up just working from the stock fuse box to each circuit and labeling it. Then im going to lay out the new harness and figure out which circuits correspond and work form there one section at a time.
12-01-2009, 05:17 PM | #5 |
I just did this job....Never wired anything before either. I took out the old harness in one piece and tried using a marker and tape to labe the wires i cut and where they cam from...If you have issues later you can go back to the old harness and look how it used to be. Also, even tho the rebel kit isnt the same as stock, the stock wiring diagram will be helpfull when tracing "problems if you run across any.
The biggest problem i had was with my old column. The wire colors were not right and wires were melted inside the tape when i pulled it apart. So i ended up doing s guess and sheck method using the flasher power and a test lite. Everything else just took time and patients. Good luck. Also DO NOT CUT if possible until you are sure you have the right connections made. I hooked everything up and tested it all then after i had it all working I disconnected, cut and routed the wiring nice and clean using tape and zip ties. Also, im a newbie so I ended up burning out a few fuses during the guess and check stages, so keep an eye on your fuses and have a few spare one kicking arround. Jory Keep in mind this is not advise coming from a mechanic...Im new at it just like you , I did it and i probably didnt do it the propper way but...its done and it looks pretty alright. LOL All that wire is scary looking and i was pretty much dazed confused and frustrated for a week while i did this but its worth it inthe end. |
12-01-2009, 10:46 PM | #6 |
One foot in front of the other
You know that is (in my opionion) one of the fun things about messing with these old trucks. Getting to do something that you never did before- by just diving in- and then having the satisfaction of knowing "Hey- I did this" Also remember there is alot of info here and people that are knowledgeable AND are willing to help.
