12-01-2009, 06:22 PM | #1 |
High Hump or Low Hump
I just got my high hump cab back from the body shop and before getting started putting it back together, I am considering changing the high hump to a low hump. My question is twofold: 1) what is involved in changing it over and, 2) what are the pros and cons to each? Thanks. Joel
12-01-2009, 07:15 PM | #2 |
Active Member
Re: High Hump or Low Hump
Personally, I'd leave it as it is. Not too many of those and once you carpet it you can add a conosole or some other component on top of it.
If you really want to get it out, you'll have to do some cutting and welding. You'll have to find an old discraded low hump cab that you can cut a carfully measured section out of or order you a floor pan. Either way it will involve a lot of work. |
12-01-2009, 07:18 PM | #3 |
its all about the +6 inches
I like the high hump personally, I can place my right foot on there and then lean my elbow onto my knee, kinda move around a bit on a long drive. (throttle with my left foot when doing this)
To swap over, you'll need to cut the low hump out of a low hump cab, and either make it into a bolt in piece, or weld it in place on your floor. The only pro of the high hump is room for a larger trans, and more air flowing around it. Even though you can fir a big block and a TH400 under a low hump, the added space for air flow helps keep the temps down on the inside floorboard. My low hump caddy425/TH350 which has less than an inch of room in places, will warm up my (uninsulated) inside floor to over 100 degrees on the freeway in the summer. (checked with an infared non contact radac gun) Seems more people like the small hump, I personally like the high hump myself. |
12-01-2009, 10:07 PM | #4 |
Man of Mini-Talents
A con to changing it over will be you're going to screw up a lot of fresh paint doing it.
12-02-2009, 12:08 PM | #5 |
67cheby
lets see some more pics of the truck
12-02-2009, 12:12 PM | #6 |
[QUOTE=Longhorn Man;3649526]I like the high hump personally, I can place my right foot on there and then lean my elbow onto my knee, kinda move around a bit on a long drive. (throttle with my left foot when doing this)
QUOTE] Dude, you need to invest in CRUISE CONTROL! |
12-02-2009, 03:16 PM | #7 |
67Cheby,
Here is where it sits for now.....18* degrees for the next 5 days so its' just going to have to sit for now. I have a lot of things to do that I can do in the basement such as put together gauge cluster, clean wiring harness etc. I keep telling myself its' a journey not a destination! |
12-02-2009, 03:22 PM | #8 |
67cheby
WOW very detailed ,looks killer!! cool valve covers, are those the doors covered up on the pass side??? looks like progress to me , i cant wait to get some paint on mine
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 12-02-2009 at 03:25 PM. |
12-02-2009, 05:21 PM | #9 |
12-02-2009, 07:28 PM | #10 |
Not worth the work to convert in my opinion.
I cut out my low hump for tranny clearance. |
12-02-2009, 09:35 PM | #11 |
Lemme show you something!!
I kinda dig the high hump. It will be easier to fab up a console between the seats, plus as LHM sez...it provides a bit more airflow around the tranny.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
12-02-2009, 10:26 PM | #12 |
I agree with the others Joel, you're too far along to change it now!
I got your email, and didn't respond right away, so I forgot. But I've got my eyes open for a bed for ya.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
