Old 12-01-2009, 11:53 PM   #1
KazuyaIB
Tach swap question.
Just recently got a gauge cluster with tach from a 76. Wondering if (after taking guages apart and modifying) the tach will work on my 91 wiring (got from burban for tbi swap) for my truck, if i route all the tach wires to distributer and +, -? Read in Crossy guide that you cant due to speed sensor (VSS) feedback needed for computer. Wondering if someone made this work...
KazuyaIB is offline   Reply With Quote
Old 12-02-2009, 12:13 AM   #2
78-5.3
78-5.3's Avatar
Re: Tach swap question.
so you have a 91 truck blazer burb?? and you want the tacho from a 76 to fit into the cluster and for the wiring to work??? i dont think it will im going a similar route 91 cluster with camaro tacho into my 78 truck the plug in the back is going to be the problem i think i have to cut into my cluster !!! i never went for a truck tacho coz of the 5000 rpm limit!!!
78-5.3 is offline   Reply With Quote
Old 12-02-2009, 12:37 AM   #3
KazuyaIB
making the tacho fit and the small fuel gauge fit my 91 cluster on my 91 burban wiring, on my 86"TRUCK" is not the problem(put TBI with 91 burban wiring). I am asking if the Tach off a 76 cluster can be made to work on the TBI system stock distributer if i just hook it up to the distributer and +/-.
Old 12-02-2009, 06:45 AM   #4
ghettoluxury
ghettoluxury's Avatar
yes your 86 still has an HEI distributer.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 12-02-2009, 09:47 AM   #5
b454rat
I took a cluster off a 79 and put it in my old 87, worked fine. I think your gonna have to rewire the gauges to get them to work, it's gonna be different and for the VSS speedo.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 12-02-2009, 11:41 AM   #6
KazuyaIB
Thx, hopefully everything goes great and il post results when i finish
