gauge lights 70 GMC
Some of my lights dont work. The speedo light does and one of the fuel lights does but the rest dont including my left turn light. I have pulled all the bulbs and checked them.. Whats my next step? Replace the wire board on the back of the gauges? I started to pull the dash panel off yesterday but decided to wait since the weather dropped and my only other vehicle is my Harley.
1970 GMC truck ![]() 1988 Harley 1200 Sportster ![]() |
Re: gauge lights 70 GMC
If the bulbs were good when you checked them. You could try cleaning the contacts on the holders. I used some fine emery cloth to insure good contact. If you can see the circuit and it has some built up crud you might try a pencil eraser to brighten it up. I would try that before I replaced the circuit board.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Ok Ill try that this weekend when I have enough time to pull it apart.
if you're going to b pulling them out to clean i'd just change out the bulbs too i've found new brighter than 40yo ones
I might do that. At 4 bucks for two bulbs changing them all will get kinda expensive.
Wow thats pretty high i think mine was like 5$ for a box of 10 or 12 not sure pm me if you need some i got some extras ill give you
70 SWB STEPSIDE 70 BLAZER 09 challenger |
I got them at Advanced Auto. I think I will do some shopping around to find a better price then.
When you have the sockets out check them with the bulbs in them with an ohm meter. I have run into bad sockets that don't work even with new bulbs.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Im toying with the idea of taking it apart and painting the gauges and needles and installing some leds.
http://www.thehoffmangroup.com/auror...e.php?gauge=93
This would look sweet in the dash.
1970 GMC truck ![]() 1988 Harley 1200 Sportster ![]() Last edited by kevmic28; 12-03-2009 at 10:55 AM. |
One day.....
Kevmic check out this thread:
http://67-72chevytrucks.com/vboard/s...inting+needles I just did it to mine and am very happy the way it turned out. Also, i now that someone mentioned about taking very fine sandpaper and sanding the traces on circuit paper. I had to do that. I went out and bought 6 new bulbs and it turned out that i only had 2 bulbs that were blown. The sockets were the problem. What I did to fix that was sand them as well. There are 2 tabs that actually make the contact with the circuit paper, I sanded those. I also sanded the inside where the actual bulb makes contact with the socket tabs. Good luck. Hope this helps. DZL1. |
