Old 12-03-2009, 12:29 PM   #1
yellowblazer1969
yellowblazer1969's Avatar
Need help with exhaust backfire
When i crank the blazer it runs fine but whan i try to drive it and accelerate it backfires out of the exhaust. I am not sure if it is doing it out of both sides of the exhaust. I understand that usually exhaust backfires mean too much fuel is being delivered and it is igniting in in the exhaust. Can anyone tell me what to adjust on the carb, is it the screws or the return spring. Could this be caused by anything else?
Thanks, chris
YELLOWBLAZER1969
yellowblazer1969 is offline   Reply With Quote
Old 12-03-2009, 01:34 PM   #2
siksilverado
Re: Need help with exhaust backfire
HAVE YOU CHECK YOUR TIMING SPARK PLUG GAP AND CONDITION INCLUDING CABLES CAP AND ROTOR TOO VACCUM LEAKS OR THE VACCAUM ADVANCE
SAL
siksilverado is offline   Reply With Quote
Old 12-03-2009, 02:58 PM   #3
yellowblazer1969
I set the timing replaced the plugs and gapped them replaced the wires, fairly new cap and rotor on a mallory setup without vac advance.
thanks, chris
YELLOWBLAZER1969
Old 12-03-2009, 03:32 PM   #4
lks dcvn
lks dcvn's Avatar
In my case it was an exhaust leak at the manifold/exhaust tube that caused the backfire.
Upon rapid acceleration and then taking my foot off the gas would lead to a nasty backfire and if I let my foot off the gas slowly - it would be less likely to occur.
I ended up replacing my manifolds and the entire exhaust - but the leak I had that caused the backfire was between the manifold and the exhaust tube(s).
Good Luck!
lks dcvn is offline   Reply With Quote
Old 12-04-2009, 04:34 AM   #5
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
This may not be it but a bad coil can cause backfiring.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
