Old 12-03-2009, 11:40 PM   #26
Fatback
Fatback's Avatar
Re: What brand of spark plug?
I have used Autolites....After 30 years,I've never had any trouble.
I have bought one set of AC Delco....One died after about a month, Replaced it with one of the old Autolites I removed.
That was my first and last set of AC's
70 C/10 LWB
69 Cougar
68 Mustang
68 GMC 4X4 SWB
Fatback is offline   Reply With Quote
Old 12-04-2009, 12:36 AM   #27
highperf4x4
Originally Posted by tomtuna1978 View Post
have been a technition for 18 years and i have made more money on people putting bosch platinum plugs in theyr car than brake jobs ! they foul out every time ! put factory plugs in it and you will never have a problem !
Exactly. A platinum plug is designed for fuel injected and computer controlled engines that burn much more efficiently at even temperatures. Even then they don't last as long as a standard plug. The platinum electrode is so small that it can't keep itself cleaned off in a carbureted engine with so many rich spots and carbon. The bigger the electrode the better. As long as you're running the right temp plug for your engine and throwing plenty of juice (like an HEI or msd setup), you won't beat a standard ac delco.
I run AC Delco R45TS in mine with 50,000 volt HEI and 8.8mm accel wires.
Champions are junk
Autolites are not far behind.
highperf4x4 is offline   Reply With Quote
Old 12-04-2009, 02:38 AM   #28
'72customdeluxe
NGK UR4 v-power's, had the best luck with these
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 12-04-2009, 07:27 AM   #29
A split plug is an attempt to compensate for a weak ignition.if you want more or hotter spark,start with the distributor/coil.A standard plug will take all you can give it.
Here`s a fun little thing.Take a champion spark plug and any other spark plug,hold both at the base,and strike the porceline together.Every time the champion will break.
Old 12-04-2009, 08:52 AM   #30
rwolf9653
more ideas than money
rwolf9653's Avatar
I am really suprised at all of the hate for autolite!?
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 12-04-2009, 09:50 AM   #31
Jim_PA
I've been running them for the last 10+ years in 4 different vehicles, never had one go bad.
Jim_PA is offline   Reply With Quote
Old 12-04-2009, 09:55 AM   #32
bamabaxter
bamabaxter's Avatar
Same here....never had a problem with my autolites. Running a set of 8924's in my aluminum heads gapped @.045, barely rolls over once before it fires right up.
'72 Chevy C10
383, 700r4, 3.73's
A little rust never hurt anyone. I consider it weight reduction.
bamabaxter is offline   Reply With Quote
Old 12-04-2009, 04:20 PM   #33
'72customdeluxe
Ok... Accel super coil and their performance module, used to have 8.8 spiral pro wires until I burned one. Now crappy super stocks. Will get some 'spensive un-assembled wires soon and custom fit them because universals suck. And mine are "leaking". I have plenty of ignition power. Ngks are the same price as delcos and don't rust to ****. When I was still having various problems (like my intake gaskets) they lasted longer too. They are also short, good for headers.
Old 12-04-2009, 08:10 PM   #34
67ss&99ss
Andy
NGK in everything. Just got a set today to replace the AC's that are in my Nova.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 12-05-2009, 12:53 AM   #35
UltraBlue71
UltraBlue71's Avatar
Originally Posted by powell72 View Post
My thoughts exactly.
x3
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 12-05-2009, 02:09 AM   #36
BigChevy80
BigChevy80's Avatar
Plain black AC plugs in everything for me (even the lawn mowers). Autolites are crap in my opinion. But then again they are made by the same company that makes FRAM oil filters. Maybe that's why I won't let one near anything I own.
-Tony
Money is no object... once it's in your wife's hands.
1972 GMC Sierra
1977 Ford LTD II
2000 Pontiac Grand Prix (wife's ride)
BigChevy80 is offline   Reply With Quote
Old 12-05-2009, 02:47 AM   #37
Arad68
Trucks N Tranzams
Arad68's Avatar
AC Delco or NGK. Both are top notch.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 12-05-2009, 09:59 AM   #38
70c10-08
70c10-08's Avatar
Champion in my atv, AC Delco in my S10, E3 in my c10 and Silverado and Autolite in my 2 F#%?s
70c10-08 is offline   Reply With Quote
Old 12-05-2009, 12:41 PM   #39
Gene
Gene's Avatar
Ac Delco without a doubt, as Shane said, if GM trusts them I guess I can too. Ditto on the champions, they suck!!
Gene is offline   Reply With Quote
Old 12-05-2009, 01:16 PM   #40
highperf4x4
Well, basically from what I can tell in this thread, AC Delco is the top choice (by popularity anyway) and Champions suck @&&.
Autolites appear to be somewhat neutral.................
Old 12-05-2009, 11:31 PM   #41
VDOG
Grand PooBaa Member
VDOG's Avatar
My truck was running terrible so before I checked each plug and this is what I found. My Autolite Platiumn which are bout 2 months old are fouled out and checkout the one below. When I pulled the plug boot off, the porcelin drop out of the boot. Done with Autolites!
VDOG is offline   Reply With Quote
Old 12-06-2009, 12:24 AM   #42
highperf4x4
Autolites not so neutral again...........
Old 12-06-2009, 12:24 AM   #43
El Jay
Gone to greener pastures
ACCEL shorties, because ACs won't fit behind the headers.
Many, many moons ago, my Dad, who specialized in/did only tune ups & carburetors, was sent to the GM Training Center in Burbank, CA. He was told/taught to use OEM spark plugs; i.e. AC Delco for GM, Autolite for Ford, etc.
What he taught me has worked for me for more than a few decades.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 12-06-2009, 05:02 AM   #44
HighwayHum72
Autolite 145 copper is probably the best spark plug for our sb trucks, if you would spin that through your thick head, you might get it...
HighwayHum72 is offline   Reply With Quote
Old 12-06-2009, 01:02 PM   #45
highperf4x4
First of all don't state your opinions like they're facts. There's alot of good minds in this thread that disagree and that makes you look foolish.
Secondly, if you're going to be sarcastic why don't you quote someone so we can figure out what order we're going to start yelling at you?
Old 12-06-2009, 01:12 PM   #46
leddzepp
Moderator
leddzepp's Avatar
AC Delco
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-06-2009, 02:47 PM   #47
BigChevy80
BigChevy80's Avatar
Any plugs with the word "copper, platinum, iridium, etc" in the title are good for one thing: draining your wallet. If you have a newer engine with ignition systems that require platimum plugs then that's understandable, but these engines aren't state of the art technology. It's like putting a hubcap on a tractor. It might look purdy, but other than that it serves no purpose. But far be it from me to tell people how to waste their own money...
-Tony
1972 GMC Sierra
1977 Ford LTD II
Old 12-06-2009, 03:29 PM   #48
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Have used Autolites for years. We have even used them in the dirt track car. Never had a problem.
Daren
04 Chevy Extend cab 2500HD 6.0 Liter 4x4
71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY
Rip El Jay
RIP BOBBO'S MOM
88JRFAN is offline   Reply With Quote
Old 12-06-2009, 04:01 PM   #49
VDOG
Grand PooBaa Member
VDOG's Avatar
This was the first time I ever used Autolites, normally I Champion's were in my truck. Thought I would try something different. Now my engine is in need of a rebuild so I dont expect the plug to make it that much better.
Heck I dont know, I came here to see what was the plug of choice was, but it looks like were all using what works for us. I bought NGK's, and I will keep you posted.
Old 12-06-2009, 11:04 PM   #50
Legolas894
Chemist under the hood...
Legolas894's Avatar
I think this is really the Coke vs Pepsi for most except high performance. I took out a really old set of Champions in the 283. Replaced them with another set of Champion (same type). No issues so far. I'm not drag racing this 42 year old engine. I probably will go for AC Delco next time (I usually go OEM and didn't think about that when I bought the Champions since they were already there).
My Astro van and Caprice wagon are AC Delco.
My wife's Mazda has Bosch Iridium but that's fuel injected and there's only 4 plugs to buy so who cares.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
