Old 12-03-2009, 07:31 PM   #1
Chuck Nukem
'66 Project in Texas
Hey guys how yall doin? This is my first post, id been lurking on the forum for a while, but a few weeks ago i came home with this beast. This place seems to have a wealth of knowledge, and im certainly glad to be here! Its my first time restoring anything so im def gonna have some questions as i make my way through this!
the first question ive got is about the radiator. the one i have doesnt seem to match what autozone/lmc say mine is. it looks like the 60-62 radiator from this place
Mine
60-62
63-66
my truck has all the mounting brackets for the earlier radiator. Has anyone else had this discrepancy?
I also need a little help on engine/transmission identification. Im pretty sure its a 283, but not 100%. The trans, its a 4 speed with a granny gear that someone put it afterwords. What might be the best way to go about identifying it?
Thanks guys,
Charles
Chuck Nukem is offline   Reply With Quote
Old 12-03-2009, 07:41 PM   #2
198plus
198plus's Avatar
Re: '66 Project in Texas
Welcome.......Looks like a pretty nice truck.
198plus is offline   Reply With Quote
Old 12-03-2009, 08:05 PM   #3
drogers
drogers's Avatar
Welcome to the board. Someone will jump in here shortly with some info on that radiator.. I have not been at this long enough to know for sure..
My Build "63 Stepside"
Major Components
71 350 stock
86' 700R4
My Front Disc Conversion
drogers is offline   Reply With Quote
Old 12-03-2009, 08:31 PM   #4
TheDark1
Intentionally Left Blank
TheDark1's Avatar
Welcome, I do believe you are correct on the radiator. All of the ones I've seen were like the square one, with a top and bottom bracket to hold it in place. They may have had some cross over to other years though, I'm not an expert on anything. You'll need to get numbers off of the block and post them to have an idea about the engine. There should be a flat pad on the passenger side of the block by the head, under the a/c compressor, with some numbers stamped into it. Post all of those and someone will be able help. Nice truck, a '66 big window with A/C and V-8. Cool....
Oh yeah, if you need help or info, ask before you break something. If you don't, everyone will point and laugh. Just kidding, everyone is here to help each other.
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 12-03-2009, 09:02 PM   #5
MXmaniac
MXmaniac's Avatar
Welcome from Denton!
I'm pretty sure your transmission would be the SM420, but since you say it isn't original it might be the later SM465.
Here's some pages to get you started on the tranny ID:
http://www.novak-adapt.com/knowledge/sm420.htm
http://www.novak-adapt.com/knowledge/sm465.htm
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 12-03-2009, 09:40 PM   #6
LILRED66
LILRED66's Avatar
Welcome to the forums from Kansas City, KS. It appears you have a good start on a daily driver or project.
The radiator appears to be from an early '60-'63 Chevy truck, which, for the most part, would be interchangeable with the 4-5-6 Chevy trucks. Additionally, if the top tank is stamped with HARRISON, you have an original or factory replacement. The HARRISON is not currently offered in the aftermarket...some care and some do not, I just thought I would let you know.
A 283 was the only V8 available in the Chevy C10 (1/2 ton) trucks from '60-'65 and the 327 became available in 1966, so you could possibly have a 327, but I would bet it is a 283, only because there were so many of them produced with the 283/SM420 combination. I would venture to say the 4-speed, granny low transmission is factory, as well.
If this is your first project, I feel compelled to offer some thoughts:
1. Have a plan...make a list of the things you want to do. Although plans change as money and time allow, a plan is better than no plan.
2. Only tackle items that keep the truck driveable, within reason...by doing so, you will be able to enjoy the truck. Many ambitious plans have fallen to the wayside, because the project sat in the garage for several months due to limited funds, time, knowledge or a combination of all three, only to become someone else's project. Try to tackle items one at a time, so you can have it back together by the end of the night or the end of the weekend.
3. There are some extremely talented individuals on this site, that make some of the difficult tasks, like bodywork, patch panels, suspension mods and painting, seems easy, so keep in mind, many of these guys are seasoned veterans or have acquired their skills over a long period of time or on a previous project. Many times, a project turns out to be more difficult than perceived and the owner loses interest or their spirit is broken because it didn't come to them as easy as it appeared when others did the same task.
I am not trying to preach, only help you avoid some of the pitfalls to acquiring a truck, that turns into a project, that turns into a burden and the fun is lost in the process.
Good luck with your project and keep us posted on your progress. We like lots of photos.
LILRED66 is offline   Reply With Quote
Old 12-03-2009, 10:04 PM   #7
62 short step
62 short step's Avatar
Welcome! Looks like a good truck. That is some good advice mentioned above, good luck with it and have fun!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 12-03-2009, 11:30 PM   #8
drasticwagon
drasticwagon's Avatar
Awesome , Have fun. I am down the highway in Haslet.
drasticwagon is offline   Reply With Quote
Old 12-04-2009, 12:11 AM   #9
Ynotnow817
Ynotnow817's Avatar
Nice truck. Looks like your steering wheel and mine have something in common.
Ynotnow817 is offline   Reply With Quote
Old 12-04-2009, 02:02 AM   #10
Captainfab
60-66 Nut
Nice truck to work with.
That's some good advise Tony gave......can't add much to it.
Old 12-04-2009, 11:05 AM   #11
62gmc910
62gmc910's Avatar
Couple of identification tips 283s had a no or a tiny balancer , SM420s reverse is beside 4th , SM 465s reverse is beside 2nd. NICE score on the truck and as tony said 60-63rad but i believe the support was drilled for that rad right up to 66?? if you have cooling issues I think a 76 ish Nova cross flow rad will fit between the inner fenders cross flow is way more efficient
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-04-2009, 12:45 PM   #12
816allen
816allen's Avatar
Cool truck man!
96 Burban Sold
99 Z71 Sold
65 C10 Sold
72 C10 Sold
87 Short Bed Lowered Daily Driver
http://s623.photobucket.com/albums/tt314/sswagon/
http://www.chevygmcofkc.org/forums/forum.php
816allen is offline   Reply With Quote
Old 01-16-2016, 12:47 AM   #13
Chuck Nukem
Well boys....time to resurrect one from the dead! I have made some progress over the last 5+ years...getting ready to tie this one up
Old 01-16-2016, 12:50 AM   #14
Chuck Nukem
I should preface this with the fact that I did not know how to work on cars let alone restore one when I bought this...I bought it to learn and if I knew then what I know now I would have bought the stinking complete rocker panel....I was too dumb to buy a new one so I made that piece....
Old 01-16-2016, 12:54 AM   #15
Chuck Nukem
So this is the part where it took me a week to sandblast the frame because I didn't know that my air compressor wasn't big enough to air up a lawn mower tire.
I got a big 80 gallon to do the body....still took forever.
Old 01-16-2016, 01:13 AM   #16
Chuck Nukem
More torture pics...I did the sandblasting in July at my friends house. The most amusing thing happened when one of his fathers workers (father pours concrete for a living) came up to me and said "Man you sandblast that whole truck?!?....you are working too hard" You know you screwed up when a Mexican concrete worker tells you that you are working too hard...
Old 01-16-2016, 01:22 AM   #17
Chuck Nukem
Now for the bodywork....I was on crunch time with this as the plan was to tear the abandoned house that I was using to paint the truck down in October of '15...Well October came and went and I still wasn't done...so I had to call for backup!
Old 01-16-2016, 01:24 AM   #18
Chuck Nukem
I flew my friend down from Connecticut to help me do bodywork...and my mom even came to help! I gave her a sander and turned her loose...she can do bodywork now!
Old 01-16-2016, 01:25 AM   #19
Chuck Nukem
And now for color! SPI medium red and universal clear. I can't say enough good things about Barry and the guys at SPI.
Old 01-16-2016, 01:28 AM   #20
Chuck Nukem
That was my first ever paint job. Last thing for tonight. I ditched the clunky SM465 and went with an NV3500...Should be night and day. I also decided half way between finishing this thing that it would be nice to have disc brakes....so now I am in the process of changing over to an 86 front end. Power steering, AC, power disc brakes, hydraulic throw out bearing....this thing is going to feel like a new truck I hope!
Old 01-16-2016, 09:13 AM   #21
Mathew21
Mathew21's Avatar
Great progress! Keep us updated.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 01-16-2016, 11:14 AM   #22
Chuck Nukem
Part of the reason that progress got delayed was that I got tied up finishing school. The main reason is that I started to get in to little British cars. I happened on a pair of basket cases and have been restoring one of them simultaneously with the truck. It is a Lotus Europa and the neat thing about these little cars besides that they are mid engined is that they weigh between 1300-1500 lbs depending on which one you run. The black one is a '72 model that got pulled out of the Gulf of Mexico and you can tell from the gas tanks! The green one is a '67 that is a very early production car. It is missing many of the modern comforts that we take for granted these days such as....adjustable seats and windows that roll down. The windows are actually plexi glass pop in pieces.
Old 02-11-2016, 11:26 PM   #23
Chuck Nukem
So I decided to swap to an '86 front end to get discs. I bought the 6 lug rotors off summit. I am keeping power steering from the '86 as well. Instead of chopping the frame I decided to CNC a spacer bracket out of aluminum. Hopefully I will have the front end changed over this weekend... I am dying to bolt panels back on!
I also picked up the 17 gal LMC frame mount tank. Fit like a charm!
Old 03-18-2016, 09:41 PM   #24
Chuck Nukem
Finally got the discs fitted and all the suspension restored. My bracket seems to fit just right. I guess we will find out how I did when alignment time comes...
Going to be welding the duals up this weekend. I got some 40 series flowmasters to go on it. Might get the cab on the frame before April at this rate!
Old 03-18-2016, 09:48 PM   #25
DPowers
One foot in front of the other
DPowers's Avatar
Very nice
DPowers is offline   Reply With Quote
