Old 12-04-2009, 06:02 PM   #1
Aaron104
camshaft remover
does anyone know where to get a camshaft remover or if there are any other ways to remove your cam?
and secondly which kind of puller works best for removing the lower timing gear sprocket? thanks!
Aaron104 is offline   Reply With Quote
Old 12-04-2009, 06:06 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: camshaft remover
I always use a 2 jaw puller to remove the pulley, I use longer bolts and pull the cam right out, never had problems, make sure the lifters are out first........
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 12-04-2009, 06:12 PM   #3
silverstreak
Here's a link to the ones Summit Racing has
http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
silverstreak is offline   Reply With Quote
Old 12-04-2009, 07:05 PM   #4
57larry
use a 6 inch bolt
57larry is offline   Reply With Quote
Old 12-04-2009, 08:04 PM   #5
cdowns
cdowns's Avatar
good to do b4 removing is read service manual
Old 12-05-2009, 12:37 AM   #6
71tahoe
71tahoe's Avatar
When my son and his friend did a cam swap, they just started taking stuff apart. Whatever was on the intake wound up in the intake runners. I don't know if the same care was taken putting it back together or if it happened on teardown but somehow a washer wound up in #5 cylinder. Beat the living crap out of the piston and ruined the head. I still don't know if the block is ok. It was a 2000 mile crate 350. Very sad day.
71tahoe is offline   Reply With Quote
Old 12-05-2009, 01:47 AM   #7
highperf4x4
There is more damage possible from that scenario. You will definitely need to have the crank checked for straight and the cylinder wall checked for cracks. I had a friend drop a small bolt into my carb swapping breathers on a propane setup once and the big cam and big valves let it into the #8 cylinder. It cracked the head, the block, busted the piston rings and bent the crank. Pretty much junked the motor. You might not have this much damage with a washer. Keep your fingers crossed.
highperf4x4 is offline   Reply With Quote
Old 12-05-2009, 09:48 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I just use long bolts and carefully slide the cam out..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-05-2009, 01:09 PM   #9
Aaron104
thanks for the responses! i got it out and it was the fuel pushrod. it was right in front of me and i didnt see it hah. i just pulled the fuel pump and it came right out. i can really make myself feel really stupid sometimes lol.
Old 12-05-2009, 01:18 PM   #10
highperf4x4
If you would have stated that you were having trouble I would have told you to check it.
I try not to offer to much advice anymore. Apparently there are those who will get offended.
