Old 12-07-2009, 04:46 PM   #1
79SWBchevy
which transmission do i have?
i have a 79 swb with the 250 I6. what transmission could i possibly/most likely have?
will it bolt up to a 350 or is the bell housing different?
thanks alot
79SWBchevy is offline   Reply With Quote
Old 12-07-2009, 05:58 PM   #2
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Re: which transmission do i have?
is it manual or auto? if its manual I would guess its a 3 speed on the tree, if its a auto then I would guess its a TH350.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 12-07-2009, 06:18 PM   #3
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
A guy once put it this way to me when i asked if the th400 was buying from him would bolt up to the 454 i was also buying from him.
"If you wanted to put the big block in a vega and use the stock transmission in the vega it will bolt up, i don't know why you would do that, but it will work"
I could be wrong on this and so cold the gentleman i quoted, but i am guessing not. The only problem i can foresee is clutch linkage. Also if its a three on the tree its probably an old saginaw or if its a 4 on the floor its probably an sm465 i believe.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 12-07-2009, 06:47 PM   #4
78-5.3
78-5.3's Avatar
thanks alot
no matter what it is the(standard or auto) belhousing will boltup
78-5.3 is offline   Reply With Quote
Old 12-07-2009, 06:55 PM   #5
68 TT
Still plays with trucks
68 TT's Avatar
Are the inline-6 flywheels the same as a sbc / bbc? I've never owned one so I don't know if they were unique but I don't remember any application guides listing the six with sbc / bbc flywheels & flexplates.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-07-2009, 07:11 PM   #6
ont_guy_38
ont_guy_38's Avatar
yes a sbc/bbc will bolt up to that tranny
ont_guy_38 is offline   Reply With Quote
Old 12-07-2009, 09:01 PM   #7
cableguy0
the only engine used in a rwd application that had a different bellhousing was the 2.8 v6 in trucks. its a GM just about everything is interchangeable
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-08-2009, 12:19 PM   #8
68 TT
68 TT's Avatar
Newer stuff yes, 50's, 60's, 70's & early 80's stuff no. Chevy V-8's and 90 degree V-6 share bolt patterns. Buick, Olds & Pontiac V-8's use a different bolt pattern, Caddy another.
A Caddy 500 inch motor is an incredible truck engine. A little cheaper to build including core cost than a big block Chevy.
Old 12-08-2009, 02:14 PM   #9
mhicks
mhicks's Avatar
Good link for info on transmissions
http://www.novak-adapt.com/knowledge...on_gateway.htm
mhicks is offline   Reply With Quote
Old 12-08-2009, 02:34 PM   #10
dbmx66
post a picture of what the trans pan looks like.
dbmx66 is offline   Reply With Quote
Old 12-08-2009, 11:41 PM   #11
79SWBchevy
thanks for all the responses.
it is an automatic.
as far as the pictures, it may take a while for me to get pictures up, maybe about 3 weeks.
thanks alot guys
Old 12-08-2009, 11:59 PM   #12
brothers69c-10
Suburban Hick
Since its an automatic its going to have either a th 350 or th 400. I'm putting money on the th350 as i've never heard of a th400 behind an inline 6 unless somebody has swapped it out some time between it came from the factory and when you got the truck. If its a th 350 the pan will look like a square with one corner a little different. If its a th400 the pan will look like a funny shaped texas.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 12-09-2009, 12:16 PM   #13
68 TT
68 TT's Avatar
They have done some strange stuff trans wise so I wouldn't completely rule it out but you are probably right. A T-350 is the most likely candidate.
I actually found a factory 4.3 V-6 92 vintage full size truck with a 4L80E trans in it so anything is possible.
